586,069 active members*
3,554 visitors online*
    Mar 2018
    BSolid parametric string
    I'm currently working with a Biesse Rover A 1530.
    I make a massive use of multipanel feature and parametric programming.
    I need help to create a string based on other params (eg for parametric tools).
    For example:
    if the value of 'lpz' is greater than 30mm I would like to use the milling tool: "ABC120"
    otherwise I would like to use "XX12VB".
    Someone can help me with this?
    Thanks a lot,
    Willy), sometimes I use additional variables
    Apr 2021
    8
    Re: BSolid parametric string
    Hello!
    First, change the tool selection to parametric and if you use tools with numbers, this formula works:
    ((LPZ>=30 *"16") + (LPZ<30 *"10"))
    But if you don't use tools with numbers, then make two different machinings and control them with properties -> execute machining -> LPZ>=30 and for the second machining LPZ<30
    -Sami
    Mar 2018
    Thanks, this does not completely solve my problem, but it will be very useful for my future programs!
    Thanks a lot!
