586,116 active members*
3,482 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Basswood for cutting board?
Results 1 to 2 of 2
    Sep 2022
    I found a great deal on Basswood panels at a local lumberyard. Can I make cutting boards out of it? I know they are primarily used for sculpting and carving but technically it is a hardwood. So going back and forth to try it out.
    Any suggestions would be helpful.
    Apr 2004
    5737
    Re: Basswood for cutting board?
    Are you talking about a board for cutting food on? No; basswood would be a poor choice for that, because it's so soft, with loose fibers. The distinction between hardwoods and softwoods has nothing to do with hardness; it's about whether the tree makes a different kind of wood in summer than in winter. For example, balsa wood is a hardwood, but it's very soft and light. Douglas fir is a softwood, but it's fairly hard (especially the old growth, with less space between the rings). Try "rock" maple, which is a hard hardwood. Use the basswood for something else.
    Andrew Werby
    Website
  1. Anyone have speed and feed for 3/16 basswood plywood
    By cenpen in forum Commercial CNC Wood Routers
    Last Post: 10-04-2016, 01:13 AM
  2. Cutting Board Options Recommendations Needed
    By ryanb4614 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-23-2015, 02:21 PM
  3. die board laser cutting machine
    By mornlift in forum News Announcements
    Last Post: 08-16-2013, 03:21 AM
  4. Cutting 3mm CF board
    By pall5599 in forum Composites, Exotic Metals etc
    Last Post: 05-06-2013, 06:31 AM
  5. Need help Cutting From Enroute To My Xylotex Driver Board
    By tager_rot in forum DIY CNC Router Table Machines
    Last Post: 11-08-2006, 06:11 AM
