586,069 active members*
3,389 visitors online*
Thread: Rutex 510A
Results 1 to 10 of 10
    Jul 2003
    126
    Talking Rutex 510A
    Anybody used this yet?
    Looks to be an all in one driver for both axis and torch height controller.
    Any comments, good bad?
    Any other solutions that have worked for people when building and using a plasma cutter?
    Sep 2005
    14
    bonjour avez vous des info sur les carte rutex r510a
    May 2004
    350
    I have this contorling board but have never tryed it yet. Yes it has auto torch height control and also will control your plasma after it is wired into the torch. Turning it on and off. and sencing arc voltage well worth the money and the p cut software comes with it.
    Nov 2004
    30
    Exclamation
    I just designed and built my CNC plasma table with the R510B. Table is working but I have some concerns with the driving software (I am using a demo of Steelcut- the guys who developed it are out of business). So far, the table is not able to draw perfect circles. I have attached a pen to the z axis to check the table accuracy. Rutex offer Pcut, which is Dos based and not user friendly. Will post pictures soon.
    Sep 2005
    14
    bonjour si vous avez des infos j'ai moi meme une carte r510b
    je nai pas fai d'essais .pouvez vous me dire si PCUT fonctionne bien .je crois quil y a une vertion PCUT PRO SI VOUS AVEZ DES INFO SUR LE PRODUIS
    Mar 2005
    361
    I have also used the 510b and the hardware is good but the software (pcut)
    needs help and is limited to 1000 blocks. They are coming out with new software that is for ( steelcut?) windows but I do not know when.When they get the software as good as the hardware I think it will be a good controller.
    Have fun building
    Mike Laws
    Nov 2004
    30
    Quote Originally Posted by danymetal
    J'utilise steelcut pour tester ma table. La carte R510B est un bon produit mais il faut un meilleur software qui marche sur windows. La carte est facile a connecter et je pourrai t'envoyer mon diagramme de connection.
    Here are some pics of my cnc table using Rutex R510B. For now I have some trouble with tuning the motors. I am not able to draw circles with my setting (see picture). I will need more help if I cannot set it up correctly.
    Attached Thumbnails Attached Thumbnails HPIM0615.JPG   HPIM0614.JPG   HPIM0625.JPG   HPIM0618.JPG
    Sep 2005
    14
    bonjour belle machine sa fais plaisir a voir . la table que lon voi sur les photo fonctinne t'elle avec la r510b ? Moi j'en suis au essais moteur j'utilise des reliance electric electro-craf .si vous avez des photo r510a + moteur que vous utiliser
    Sep 2005
    14
    j' ai fais des essais avec d'autre moteur mai quand je metais sous tention la r510b les moteurs commencer a tourner san lancer le programe si vous avez des info sur moteur et encodeur que vous utiliser
    Nov 2004
    30
    I use poly scientific motor C23 series (www.polysci.com )for all axes and 250CPR US digital encoder.
  1. 2000 series Rutex drives
    By rutexus in forum Servo Drives
    Last Post: 04-03-2007, 10:00 PM
  2. Rutex Servo issues.
    By ty1295 in forum Servo Drives
    Last Post: 05-28-2005, 05:10 AM
  3. Gecko vs Rutex
    By samualt in forum Gecko Drives
    Last Post: 10-21-2004, 07:48 AM
  4. Mach2 & Rutex relay board.
    By ynneb in forum Mach Software (ArtSoft software)
    Last Post: 08-22-2004, 07:50 PM
  5. Mach2 and Rutex
    Last Post: 03-31-2004, 09:37 PM
