586,070 active members*
3,543 visitors online*
Thread: Punch emboss
Results 1 to 3 of 3
    Jun 2010
    56
    Punch emboss
    We have an emboss process which demands making a hole (7.25 mm) first and embossing in a second operation with an Amada Vipros 2510C turret punch.
    Since this is the first time we do it we bought an "A" type for the first operation and a "B" type (which was necessary) for the second operation, but in our case this demands the striker to be moved between the inner track and the outer track of tools.
    We received the test sample from Wilson and the tools perform well when the two operations are concentric but in our case they are not perfectly aligned and the emboss is wrong.
    My understanding is that we should move the first operation to the outer track (which is not right away possible because the tool does not have a keyway) so that the striker does not move, so that once the turret rotates both operations are perfectly aligned.
    The other option that comes to my mind is that we should buy a new 7.25 mm round tool but in "B" size instead.
    My question is: is my reasoning right ? Can anyone advise what is the best way to do this ?
    Jun 2010
    56
    Re: Punch emboss
    So, I will answer my own question. My reasoning was absolutely wrong. The striker does move from the inner to the outer track, but that in no way means it affects the turret alignment.
    The problem was due to a bad tooling type configuration, the emboss operation must be configured properly as a forming tool.
    Oct 2022
    Re: Punch emboss
    Quote Originally Posted by otrotabi View Post
    it should not matter that you use inner and outer tracks since your strikers aligns itself. i punch with a 201round which is a a station and emboss with a b station and also use wilson tooling keep it a for the small hole and b for the emboss. is your machine clutch driven or is it hydraulic.
  1. Seeking American tooling adapters, punch holders, punch clamps
    By Marankie in forum Bending, Forging, Extrusion...
    Last Post: 12-29-2020, 09:24 PM
  2. Replies: 0
    Last Post: 09-22-2020, 02:14 PM
  3. Strippit LVD Turret Punch Press 1250 H20 - runs in dry mode, not with punch
    By Charlie-B in forum Uncategorised MetalWorking Machines
    Last Post: 09-22-2020, 01:31 PM
  4. cnckad punch off the table euromac BX1000 top punch
    By renatomail in forum Post Processor Files
    Last Post: 10-19-2017, 11:55 AM
  5. 3d z level emboss
    By csmoak25 in forum BobCad-Cam
    Last Post: 04-11-2010, 10:30 PM
