586,119 active members*
3,607 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > M02 unlock spindle orientation lock
    Aug 2011
    419
    Hi
    is there a way M02 command don't to unlock M19 locking position?
    My program format
    M05 M09
    M19 C123
    M02
    M19 position is lost and spindle don't lock after program end. I don't want it.
    "Imagination is more important than knowledge."
    Jun 2015
    4154
    Re: M02 unlock spindle orientation lock
    M19 C123 M09 ( + G00 Xup Zright M63 should also work )
    M84 M64 M0
    GOTO TOP
    M02
    if m19 is there, you no longer need m5
    Aug 2011
    419
    Quote Originally Posted by deadlykitten View Post
    NBEGIN
    M05 M09
    M19 C123
    M0
    GOTO NBEGIN
    M02
    It is perfect and fast solution. Thank you
    Apr 2009
    1262
    There is a parameter for that under “spindle “. You don’t want to use a “GOTO” because load monitoring, parts count, cycle time counters , alarm C , SDF programs and others need to see the M02 in order to function properly.
    You could potentially not stop running when waylube runs out or when load monitoring is trying to stop the machine.
    Best regards,
    Experience is what you get just after you needed it.
    Jun 2015
    4154
    hy mr wizard if i may, sdf performs slower than min; also, each atribute, like load / count / times / you name it, can be handled without issue
    on newer machines, sdf has it's place, like for pallet systems, etc, or where non cuting programs ( preparatory ) are mixed with cutting, but is not critical to use it
    as for looping simple operations, even if it works, again, is not must to use it
    from nesting level, sdf works with min, just as min works with ssb ... sdf is a thing for low memory machines / kindly
  1. Replies: 15
    Last Post: 08-06-2022, 05:14 AM
  2. Replies: 0
    Last Post: 06-10-2021, 02:45 AM
  3. Spindle orientation prob 7 param will not unlock
    By LakesideMachine in forum Haas Mills
    Last Post: 05-10-2011, 01:34 PM
  4. Spindle Unlock
    By Mark and Poco in forum Okuma
    Last Post: 02-10-2010, 03:00 PM
  5. 4th axis lock/unlock
    By Stebedeff in forum Mastercam
    Last Post: 10-27-2009, 03:53 AM
