586,077 active members*
3,793 visitors online*
IndustryArena Forum > MetalWorking Machines > Turning Machines > Problems with setting cnc lathe in Mach3
    Jun 2020
    26
    Hi out there. I have been facing a few problems trying to sort out the motor tuning within mach3. I am not sure if this is a software or electrical hardware problem. First off there is no wear on the lathe so that’s not an issue. The system that I have is this. A closed loop steeper motor and driver on the z axis. The original stepper motor with new driver on the x axis. The breakout board is a cheap item off eBay and uses a usb cable to connect to the pc. The power supply is 24v at 5 amps. The motors are nema 34. So this is the problem I am having. On inputting the command G0 z-30 the machine moves 35mm. At 1000 steps . If I reduce the steps to say 900 the machine then only moves 15mm . If I increase the steps by 500 the machine then moves upto 60mm. At times mainly after 5 goes it will not move at all and I need to power off and start again. This leads me to think it’s an electrical hardware problem. This happens on both axis. I am in a sort of position in which I could end up spending lots of money buying the wrong items. And has most of the stuff needs to be imported into the U.K. and the import duties sky high I need to get it right straight out of the box. Can anyone help. Thanks.
    Aug 2008
    406
    Re: Problems with setting cnc lathe in Mach3
    You need to calibrate each motor in the software under axis tuning has that been done?
  1. Help setting up Hall effect sensors on Mach3 BOB CNC
    By Mr.Chips in forum CNC Machine Related Electronics
    Last Post: 07-27-2021, 08:05 PM
  2. Replies: 0
    Last Post: 04-14-2021, 02:25 PM
  3. CNC-3040Z-DQ (USB) Setting up with Mach3
    By pheelan in forum Chinese Machines
    Last Post: 01-15-2016, 10:13 PM
  4. Need Help Setting Up Sherline CNC Lathe!
    By bedheadben in forum Mini Lathe
    Last Post: 10-07-2012, 12:54 AM
