586,089 active members*
3,893 visitors online*
Results 1 to 6 of 6
    May 2008
    77
    Servo tuning setting location
    Had a failure to launch issue with UCCNC the other day that I finally tracked down to network interference from my network switch. Once that was fixed everything was fine.
    However in tracking this down I put a backup laptop onto the CNC to see if the issue was with the laptop that was running the machine. Once I solved the network problem that spare laptop activated the servos but they wouldn't move the router. They'd just hum as though they hadn't been tuned yet. I put the original laptop back on the router and all was good.
    This made me wonder if I had misunderstood where the servo tuning settings are saved. It was my understanding they get saved to the ETH300 board. However if that was indeed the case shouldn't the backup laptop had run the servos properly? Or am I right about the tuning settings being on the ETH300 board and it was likely just other axis configurations that hadn't been set up properly on the backup laptop that were causing this result.
    BH
    Re: Servo tuning setting location
    The first thing that comes to mind, is to run the Utilityxxx software to reestablish the connection. Maybe you just need to whitelist the device on the networks firewall.
    Please check this FAQ Post for other thoughts: https://www.cnc4pc.com/faq/article/m...is-not-working
    Did you get this sorted out?
    Arturo Duncan
    https://cnc4pc.com
    May 2008
    77
    [QUOTE=arturod;2525036]Did you get this sorted out?
    Arturo Duncan
    https://cnc4pc.com[/QUOT
    If you read my original post more closely you'll see the problem was resolved before I even posted the event. The question was on my understanding of where the servo tuning data is stored.
    BH Davis
    15362
    [QUOTE=bhdavis1cnc;2525040]
    Quote Originally Posted by arturod View Post
    Arturo Duncan
    BH Davis
    Servo Tuning is normally all saved in the servo drives, there are some settings in the control software that would need to be setup for each axis, so most likely your backup computer control software was not setup correctly.
    Mactec54
    May 2008
    77
    [QUOTE=mactec54;2525084]
    Quote Originally Posted by bhdavis1cnc View Post
    Thank you. That is what I was suspecting to be the case. I'll have to look more closely at the axis settings on that backup laptop.
    Much appreciated.
    BH
  1. NH4000 tool setting location
    By imjustakid in forum Mori Seiki Mills
    Last Post: 09-18-2015, 07:01 PM
  2. setting start location.
    By custombuilt15 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-27-2015, 10:12 PM
  3. Setting Home Location, Table Travel, and Home Switch Location in Stepconf
    By northbear in forum LinuxCNC (formerly EMC2)
    Last Post: 08-25-2013, 05:07 AM
  4. Help with setting up motor tuning
    By tdnp in forum DIY CNC Router Table Machines
    Last Post: 12-23-2010, 02:57 AM
