586,717 active members*
3,206 visitors online*
    Sep 2022
    Laser Turns on 1 to 2 seconds before Moving
    Hi I have a home made CNC Table Running with Mach3 and I added a Laser to it. I have the problem that the laser turns on 1 to 2 seconds before the laser starts to move. leaving a burn dot at the start of every burn.Any suggestions would be truly appreciated.
    Nov 2008
    643
    Re: Laser Turns on 1 to 2 seconds before Moving
    What commands are you using to turn the laser on?
    Nov 2013
    4447
    Mach3 does have a couple of commands that turns the laser on or off exactly at the moment the axis starts (or stops) moving. Note that many Chinese external motion controllers do not
    support those Mach3 specific commands.
    Craig
