586,106 active members*
3,231 visitors online*
    Jul 2016
    6
    Servo wiring - one more
    Hello,
    I bought this unit: https://fr.aliexpress.com/item/10050...yAdapt=glo2fra
    I attach the manual which is not easy to understand.
    I would like to drive it with a rotary encoder (or handwheel but this is the same thing)
    Here is my wiring:
    pin 2: +24v
    pin 3: encoder phase 1
    pin 14: encoder phase 1
    pin 4: encoder phase 2
    pin 5: encoder phase 2
    pin 9: +24v
    pin 10: 0V
    and parameters:
    Pn003 = 1 (enable)
    Pn096 = 2 (quadrature encoder)
    Pn064 = 0
    Jog is working fine.
    When I set Pn3=1, the shaft hold well, if set to 0 it's free. If i connect pin 6, the shaft also hold, it seems OK
    But impossible to have a move when I move my encoder. No error message, just nothing...
    Any idea what should I do?
    I checked with 2 encoers, and also in step/dir mode with an arduino and nothing...
    Help ;(
    Thank you
    Jan 2018
    1516
    Re: Servo wiring - one more
  1. Need help with servo wiring
    By Lestraa in forum Servo Motors / Drives
    Last Post: 08-04-2022, 02:55 PM
  2. wiring check please. parallel wiring to maximum current to servo motors
    By Novett in forum CNC Machine Related Electronics
    Last Post: 10-11-2014, 07:54 PM
  3. Servo wiring question
    By scrambled in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-12-2009, 08:08 PM
  4. Wiring servo
    By Ed Williams in forum CNC Machine Related Electronics
    Last Post: 05-19-2006, 05:17 AM
  5. Servo Wiring Help
    By matt in forum CNC Machine Related Electronics
    Last Post: 04-30-2006, 12:07 AM
