586,113 active members*
3,207 visitors online*
    May 2012
    537
    Can I used Kflop to output RC servo signal?
    Hi Tom,
    Wondering If i can use Kflop to output a signal to control an RC servo? Its a 5v pwm signal and i believe it uses the width of the pulse to set a position.
    Im working on a project with one of these: https://www.servocity.com/8-stroke-2...-linear-servo/ . Im running into few issues with it accuracy. Thinking I might be able to correct some of it with c-code if I was using kflop. And if all else fails i might just need to change to an actuator that uses a servo or stepper, in which case i could use a kflop to control anyway.
    Mark
    May 2006
    4045
    Re: Can I used Kflop to output RC servo signal?
    Hi Mark,
    It can be difficult to generate precise pulses at such a low frequency. See here for an example which disables/enables a PWM to do it. I think the pulse resolution is ~ 0.5%.
    HTH
    TK
    http://dynomotion.com
    Dec 2014
    78
    If kflop isn't doing what you want I'd look into using an arduino to control the servo. My father in law just showed me a setup he is using an arduino to control one of those and I know you can control RC servos with them too. I would guess you could interface an ardiuino with kflop if you needed.
    24221
    Not only is the PWM frequency very low, 20ms with the pulse width from 1 to 2 ms, making it difficult to make a controller unless it is a dedicated Picmicro or other IC such as 555 etc.
    Albert E.
    May 2006
    4045
    The link to the KFLOP program uses a software/hardware approach. The 8-bit hardware PWMs are programmed for 435Hz which gives a hardware pulse resolution of 9us. Then the software disables the PWM for 7 PWM cycles and enables it for 1.which results if a frequency of 54Hz. A 200us safety window is reserved at the end of the PWM cycle so the software is guaranteed to have sufficient time to properly disable/enable it before the next cycle. I think overall the pulse resolution will be ~ 1%. Or for 8 inches of travel 0.08 inches.
    TK
  1. JP5 Port on KFLOP not outputting any signal
    By ychen488 in forum Dynomotion/Kflop/Kanalog
    Last Post: 03-24-2016, 11:41 AM
  2. kflop/kanalog tacho signal
    By LarsSweden in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-20-2014, 07:03 PM
  3. Kflop to Mach3 signal bit
    By frankee in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-13-2012, 10:42 PM
  4. 1.6V-3.0V random signal voltage parallel signal from output – Any advice?
    By cjchands in forum Mach Software (ArtSoft software)
    Last Post: 11-12-2009, 11:36 AM
  5. No Output Signal
    By tz1238 in forum Machines running Mach Software
    Last Post: 01-27-2008, 09:57 PM
