586,236 active members*
2,999 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > no puedo configurar mi vfd 380v 3kw
    Jul 2015
    tengo un splindle de 380v 3kw y su vfd 380v 3kw refrigerado per aire pero los compre por separado le pedi al bendedor que me ayudara con las parametros pero me puse de creativo y lo restablesi de frabrica pero aora no puedo confugurarlo para que me de las 18000r/min si al guien me podria ayudar con los parametros que devo de meter gracias
    Apr 2019
    154
    Re: no puedo configurar mi vfd 380v 3kw
    Quote Originally Posted by ICARDENASM View Post
    It's probably better to formulate your problem in English. I have now put it into the translator. Hope it´s correct:
    I can not configure my vfd 380v 3kw
    I have a 380v 3kw splindle and its 380v 3kw air cooled vfd but I bought them separately I asked the seller to help me with the parameters but I got creative and I restored it from the factory but now I can not set it to give me the 18000r/min if anyone could help me with the parameters I should put
    thanks
    Community Manager <a href="https://de.industryarena.com/" target="_blank">https://de.industryarena.com/</a>
  1. VFD for 380V 3 phase motor input (3P+N+T) Belt Grinder
    By riandavidson in forum Spindles / VFD
    Last Post: 04-12-2022, 03:58 PM
  2. VFD Settings for 5.5kw, 380v, spindle, Help please.
    By jmercado3120 in forum Spindles / VFD
    Last Post: 03-06-2022, 06:01 AM
  3. 3kw motor and vfd
    By Atomas0907 in forum Spindles / VFD
    Last Post: 08-12-2018, 09:40 PM
  4. Replies: 7
    Last Post: 03-22-2017, 03:48 AM
  5. Running 440V VFD with 380V
    By Khalid in forum Phase Converters
    Last Post: 08-20-2010, 05:18 PM
