586,104 active members*
3,376 visitors online*
    Jun 2019
    G71 canned cycle type 2
    Sanjeev
    Dear sir
    I need help
    I have takisawa t c 200 fanuc21t control
    Basically I have done v groove roller
    We now presently doing line programming
    Single line programming
    G71 type 2 program machine is not reading I got Alarm ps0323 the first shape of program is a command of type 2
    My program is below
    0471
    G28 u0w0
    N1
    G28 u0w0
    M1
    T0505 G97 s120m3
    G50s1300
    G96S210m3
    G0 x110. Z5 .m8
    G72 w0.5 R1.
    G72 p10q20w.2f.25
    N10G0z0.0
    G1x35.
    N20 G0z2.
    Gox101.z2.
    G71U1.2R1.
    G71p30q40U.3W.2f.25
    N30G1x98.z.2
    Z-18.
    X65.Z-45.
    X98.z-72.
    X-90.
    X110.
    N40G0Z2.
    Z20.m9
    G28U0W0
    M1
    M30
    Please if any mister in this program can you help me
    Oct 2022
    Re: G71 canned cycle type 2
    Have you written G72 instead of G71 in the programme?
    May 2007
    1003
    Can I assume X-90. should be Z-90.? Change N40G0Z2. to N40X110, delete the G0Z2. and put the G0 on the line with Z20.M9.
    I've only done G71 cycles with X-axis always going in the same direction (plus for O.D., minus for I.D.). However, it is my understanding you can reverse X-direction with the addition of a Z-value in the first block of the cycle so I think you are fine there.
    EDIT: A canned cycle always returns to its starting point at the end of the cycle so you could have:
    N40X110.
    G28U0W0M9
    M1
    Looking further I see you did the same thing with the G72 cycle. Should read N20X35. Delete the N20G0Z2. block. This is assuming you aren't turning a diameter at X35. If you are then it would be:
    G1X35.
    N20Z.2 (no G0)
  1. TL-1 and G71 Canned Cycle Issue
    By kstopp in forum Haas Lathes
    Last Post: 03-02-2017, 06:24 PM
  2. G71 Canned Roughing Cycle Standoff
    By poc_uk in forum G-Code Programing
    Last Post: 05-23-2014, 11:56 AM
  3. G71 canned cycle
    By kaminc in forum G-Code Programing
    Last Post: 12-24-2013, 09:47 PM
  4. G71 TYPE II CANNED CYCLE, I'M CONFUSED!
    By modulus in forum Fanuc
    Last Post: 04-12-2013, 12:35 PM
  5. G71 CANNED CYCLE
    By Jking7489 in forum G-Code Programing
    Last Post: 05-06-2012, 07:18 PM
