586,341 active members*
3,370 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > UCCNC Control Software > Leaving Mach3 for UCCNC - Hardware migration question
Results 1 to 7 of 7
    Sep 2010
    76
    Question Leaving Mach3 for UCCNC - Hardware migration question
    Hi
    Fired up the router this morning to discover the latest w10 update had killed Mach3, AGAIN !
    Fair enough, it is very old software, so be it.
    I am planning on switching to UCCNC and am hoping it is as simple as pulling out the Smoothstepper and replacing it with a UC100. Downstream is a KTA-205 https://oceancontrols.com.au/KTA-205.html that has served me very well for many years.
    Apart from the software learning curve, am I going to be that lucky ??
    BTW, PC is an i7 with 12Gb RAM, I expect that will handle UCCNC.
    Thanks in advance
    Jan 2018
    1516
    Quote Originally Posted by uspl View Post
    Hi
    Thanks in advance
    If already using a smoothstepper with a breakout board. May I suggest you forget the UC100 and get a UC400eth instead?. Ethernet is better and it has the same idc26 connections as the smoothstepper.
    Nov 2013
    4394
    Re: Leaving Mach3 for UCCNC - Hardware migration question
    what about Mach4?
    A new UC100 or UC300 or UC400 and a UCCNC license would be about the same as a Mach4 license. Your existing ESS will do Mach4 just fine, I've been using Mach4 ans an ESS
    for eight years.
    Craig
    Nov 2013
    4394
    just as a matter of interest if you do decide to get a UC100, and I certainly have no reason to disbelieve that it would not be a workable solution, don't buy one of the Chinese rip-off uc100's that abound on
    Ebay and Amazon....they are not a patch on the real thing by CNCDrive (Hungary).
    Craig
    Feb 2012
    149
    I did the same thing on my router a few years ago. I went with uc300-ub1. It worked so well I duplicated the same controller on my mill a few years later. The other thing I would consider is acorn..I agree with dazp1976, I would go with ethernet.
    Jan 2018
    1516
    Another option is to get hold of a retail version of win7 sp1. Once it's installed that's the end of it. You don't get the updating, it stays as it is and doesn't mess Mach3 up.
    Feb 2012
    149
