586,108 active members*
3,100 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > need help to achieve flange facing for 0.8mm gas kit sealing
    Aug 2007
    224
    hello experts
    I am facing an issue with flange machining to achieve a surface finish for gas kit sealing .what is the science behind the machining of flange facing for gas kit sealing?..please advice..
    regards
    asif
    Jun 2015
    4154
    Re: need help to achieve flange facing for 0.8mm gas kit sealing
    hy what issue are you facing ?
    Aug 2007
    224
    dear, please check the jpeg.
    this is a sheet metal fabricated intake manifold. the body is made from a 1.2mm sheet drawing process and the flange is 8 mm thick, which is done by the blanking process. After the sheet metal process has been completed the body and flange will be joined by the MIG welding process. the problem I am facing after welding is leakage from the welding area and also under the flange. there is also some distortion on the flange after welding which is not more than 0.5mm from a different area of the flange. looking for some advice about this process issue. how to maintain the flange flatness after welding or do I need to have a machine cut on the flange face after welding? if yes then which machining process and cutting layout do I have to adopt?
    regards asif
    Jun 2015
    4154
    hy you need a pressure test for weld sealing, and final flatness inspection, then decide based on results
    such sealing normaly require gaskets, and assemble does not include welding
    however, sometimes, there is used welding only for seal, without gaskets, but this is advanced process, that has inspection equipment which goes among each unit of wealding, because a leackeage could be critical
    if possible, search for someone near your area, to advise you directly ... a bit of caution is required with your aproach
    if i may, where does it go ? thus maybe you can compromise it without worry
  1. Anyone have experience running gas shielded flux core without gas?
    By DarrellCurry in forum Welding Brazing Soldering Sealing
    Last Post: 07-06-2020, 01:14 AM
  2. true 2" (50.8mm x 50.8mm) steel square tube in Australia?
    By jazza in forum Australia, New Zealand Club House
    Last Post: 07-07-2013, 01:09 AM
  3. Need 8mm T-Slot clamping kit in Europe
    By Codeman in forum Benchtop Machines
    Last Post: 04-20-2010, 12:26 PM
  4. Laser/Waterjet SS 316 5-8mm (0.27/0.33) and 8mm (0.33) Polycarbonate
    By rugludallur in forum Employment Opportunity
    Last Post: 03-15-2010, 11:51 PM
  5. Gas engine to gas air compressor conversion
    By Tom Brown in forum I.C. Engines
    Last Post: 09-19-2006, 07:58 AM
