586,113 active members*
3,638 visitors online*
IndustryArena Forum > WoodWorking Machines > Commercial CNC Wood Routers > Needing a hire someone to help with mach 3 for a router with ATC
Page 1 of 2 12
Results 1 to 20 of 29
    Dec 2015
    14
    I have a cnc router with ATC.
    I need help with setting up Mach 3 or to upgrade to Mach 4 if recommended.
    I am wanting to hire someone to consult.
    Please email me with your experience.
    Thank
    Rich
    [email protected]
    Nov 2013
    4376
    Re: Needing a hire someone to help with mach 3 for a router with ATC
    if this is a new build or new installation the do yourself a favor use Mach4.
    All development of Mach3 ceased seven-eight years ago, whatever bugs it has it will always have. Mach4 is still actively developed.
    Particularly when you come to write the script/scripts for the ATC you'll find that Mach4 structure/Lua/Mach API is vastly superior to VB, the Mach3 scripting language.
    https://www.machsupport.com/forum/in...8176#msg278176
    Craig
    Jan 2018
    1516
    Quote Originally Posted by Rhyne View Post
    Thank
    Rich
    [email protected]
    Will help to tell people which control board it is using?.
    Mach3 is OK but as Craig said. It's old and Mach4 has replaced it so it's Mach4, uccnc or LinuxCNC for options.
    Dec 2015
    14
    Thank you for your responses.
    the machine is 6 years old, I have maybe 5 hours on it. I just retired so I have more time now. I am not opposed to upgrading to mach 4.
    The control board is a C41 PWM Rev.2.2
    Thanks for your help
    Rich
    Nov 2013
    4376
    That sounds does not like an external motion controller but just a PWM converter for the spindle. We really need to know what the motion controller is.
    Can you take some pics of all the electronics, even a shot or two of the machine.
    Craig
    Dec 2015
    14
    Dec 2015
    14
    Hi Craig
    hope this helps.
    Rich
    Nov 2013
    4376
    One of the pics you posted shows an Ethernet SmoothStepper (ESS), I excerpted one of your pics and highlighted it. This board is the heart of the motion control system.
    Mach, be it Mach3 or Mach4, generates numeric data describing the controlled point trajectory, but its the ESS that turns that numeric data into high speed high accuracy pulse streams
    which are in turn consumed by the stepper motor drivers.
    The intervening boards are just breakout boards......they are really only buffer amplifiers between the ESS and larger hardware....they don't really do much. For instance the board you listed
    earlier, the C41, is a board that accepts pulse streams from the ESS and generates a 0V to 10V analog signal to control the speed of the spindle......an important task to be sure, but not
    the highly critical motion stuff.
    The ESS is a good board, I use one myself, so unless you feel the need to change it I would stick with it. The ESS requires Mach, be it Mach3 OR Mach4 to run.
    It seems that there are an awful lot of other (less important) boards in there as well. I seems likely you could reuse them....although the wiring confusion
    may make that tricky. A single breakout board like the MB3 (approx $180) by CNCRoom may save some of that clutter and confusion, not strictly required but
    would be a satisfying retro-fit.
    I would suggest you do a little research and decide whether you want to carry on down the Mach path or go in another direction like UCCNC or LinuxCNC.
    This is the sort of choice you should make now, rather than waste time and/or money by pursuing an idea only to later change tack completely.
    Craig
    Dec 2015
    14
    Craig can we have a conversation about all this.
    Rich
    707-975-3536
    Nov 2013
    4376
    that might be expensive, I live in New Zealand, I don't even know what country you're from, guess is US?
    Craig
    Jan 2018
    1516
    Craig
    How about WhatsApp. Is that doable?.
    I totally agree about getting the MB3.
    I went the uccnc route with uc300eth, with ucbb and a few separate isolation boards.
    Wish I'd had the £ to get the UB1/UD1.
    15362
    Quote Originally Posted by dazp1976 View Post
    He does not need to change anything he has the C41 and the other Boards he has will most likely do all he needs the MB3 won't change much
    Mactec54
    Jan 2018
    1516
    Yes. What he has will all work with Mach4 just fine.
    It's all about whether he can trace all of the wiring, create a wiring diagram, and make sense of it.
    Craig was suggesting that a MB3 would simplify it all somewhat.
    Dec 2015
    14
    My immediate problems are:
    The program does not recognize the saved tool offsets.
    I will measure a tool by moving the tool to the top of the material, when I start the program it will drive the tool into the aluminum table.
    The post I am using is Mach 2/3 ARCS (inch) (*.TXT) from Vectric
    Thank you for all your help
    Rich
    15362
    Rich
    Ok this is more just a setup problem; post the first part of your program this will show how the program should act
    Have you homed the machine??
    For G54 / G43 to work the machine will need to be homed.
    What is in the Tool offset page for the Tool you are using.
    Mactec54
    Nov 2013
    4376
    That sounds more like a software/control issue rather than a hardware issue. The suggestion I made (MB3) may well tidy up the wiring and make it easier to fault find
    but I would not expect it to change the character of the machine.
    I suspect that if you look on the Offsets tab of Mach3 you may find an explanation of whats going on. To be honest I always found Mach3 Offsets to be poorly organised and sometimes
    seemingly illogically applied, and I find that Mach4's presentation and application superior.
    May I suggest you download a copy as a demo and have a look for yourself.
    Craig
    Dec 2015
    14
    How difficult would it be to upgrade to Mach 4.
    15362
    Updating is not going to change what your current programing problems you are having; we need to get that part sorted first. there is nothing wrong with Mach3 and the Smooth Stepper operation
    Mactec54
    Nov 2013
    4376
    Given that you already have an ESS, not hard at all. You'd download and install Mach4Hobby. Download and install the Mach4 ESS plugin in the plugins folder, select the ESS as active motion controller,
    and start forming your profile for the machine. I would not expect that you'd have to change any wiring.
    A cursory glance at Mach3 and Mach4 suggests they are similar....they certainly do the same job, but the internal arrangement of Mach4 is very different to Mach3....and that throws people.
    The expectation is that because something worked this way in Mach3 that it should work the same way in Mach4, but often that is not the case. This is a major source of the negative comments about Mach4
    and hampered its adoption.
    Mach3 'evolved' over a period of years, and often a feature relied on some software work-around elsewhere in the program and so became difficult to maintain. Mach4 was designed from the ground
    up, and is modular with a well defined API, a fast and lean scripting language and an editable GUI. All of these things represent a learning curve and can be very frustrating, but once that hump
    is mastered Mach4 is easy.
    Craig
    Dec 2015
    14
    Hi Mactec54
    thank you for your response.
    I have physical homing switches.
    The datum position is set to the center of the part.
    ( SADIE V CUT5 )
    ( File created: Friday September 30 2022 - 02:18 PM)
    ( for Mach2/3 from Vectric )
    ( Material Size)
    ( X= 34.000, Y= 13.000, Z= 0.750)
    (Toolpaths used in this file
    (SADIE V CUT2)
    (Tools used in this file: )
    (5 = V BIT 60)
    N100G00G20G17G90G40G49G80
    N110G70G91.1
    N120T5M06
    N130 (V BIT 60)
    N140G00G43Z0.8000H5
    N150S12000M03
    N160(Toolpath:- SADIE V CUT2)
    N170()
    N180G94
    N190X0.0000Y0.0000F100.0
    N200G00X0.8238Y-1.5406Z0.2000
    N210G1Z-0.0625F30.0
    N220G1X0.8296Y-1.4952F100.0
    N230G1X0.8361Y-1.4543
Page 1 of 2 12
  1. NEW ATC CNC ROUTER RC1530-ATC WITH LINEAR TOOL CHANGER
    By Baiansy in forum Roctech CNC Routers
    Last Post: 10-21-2021, 12:54 PM
  2. Mach 3 / Prototype CNC Router Traverse Axis Issue ? Newbie needing help :/
    By BobCAD-Trainee in forum Mach Software (ArtSoft software)
    Last Post: 04-21-2017, 07:54 PM
  3. Looking For CNC Router For Hire Northern WI
    By Ronp987 in forum USA Club House
    Last Post: 04-09-2016, 09:08 PM
  4. Woodworking ATC CNC Router RC2030S-ATC With Rotary System
    Last Post: 02-09-2015, 09:03 AM
  5. LOOKING for CNC Router for HIRE Los Angeles Area!
    By rcabinet in forum Commercial CNC Wood Routers
    Last Post: 08-24-2011, 02:50 PM
