586,103 active members*
3,771 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 16iM, on a robodrill, won't M99 repeat, won't even GOTO1 to N1
    Jun 2012
    516
    I have a robodrill w/APC and am trying to run a program
    O0001 (CHANGE PALLET CALL PROGRAM)
    (SET PROG NO FOR EACH PALLET IN QUICK NC)
    M65
    M98 P#990
    M01
    M99
    this runs, but doesn't repeat (i am expecting it to repeat forever).
    I also tried
    N1
    M65
    M98 P#990
    M01
    GOTO1
    M99
    but, to me at least shockingly it doesnt repeat
    any robodrill / fanuc guys out there know why this might not happen?
    my next move is to call this program as a subprogram using M98, but the factory pallet call program from kawatatec is as shown above, so M99 should be working on this machine, but it just isn't.
    Jun 2012
    516
    Re: Fanuc 16iM, on a robodrill, won't M99 repeat, won't even GOTO1 to N1
    this one is solved. it had nothing to do with the pallet call program.
    it was my part programs, which get posted out of my cam software with an M30 at the end. since this pallet change call program is calling those part programs as a sub program, the end needs to be M99 instead. changing from M30 to M99 in the part programs solved it
    Sep 2018
    4
    Fanuc robodrill Alfa T14 with controller Fanuc 16i-M
    Don't run program via memory card
    M198P1234
  1. Replies: 2
    Last Post: 06-03-2021, 05:35 AM
  2. Fanuc 16iM M99/M30 problem
    By CadCamSam in forum Fanuc
    Last Post: 03-26-2019, 03:43 PM
  3. Shoda 5 axis with a Fanuc 150-M Won't Boot - I need a Fanuc Guru!
    By Rocketboy52 in forum Vertical Mill, Lathe Project Log
    Last Post: 11-29-2017, 08:39 AM
  4. Replies: 6
    Last Post: 08-09-2013, 03:44 PM
  5. Fanuc OT Won't Zero
    By Bakes144 in forum Fanuc
    Last Post: 09-28-2012, 07:00 PM
