586,051 active members*
3,776 visitors online*
IndustryArena Forum > CAM Software > Postprocessor for CAM > Goal; a working post processor for Fusion 360 to Mach4
Results 1 to 2 of 2
    Oct 2008
    47
    Of course there is already one in Fusion 360s Library.
    However, my Mach4 setup+machine has problems with the initial codes.
    If I copy the g-codes into mdi, from where the actual movements start, it seems to work fine.
    Another issue is that I was not able to make homing and soft limits work properly until I flipped the Z axis in Mach4,
    (Se attached immage) Attachment 485502
    With the Z flipped, it basically works like the xyz on a MultiCam Machine. (which I sometimes allso work with)
    As you may see from the immage It has to do with where my end switches are located.
    As I understad it, MultiCam has a flipped z axis, meaning that it breaks with the right hand rule, and so they kind of follow a "left hand rule"?
    So now i can see some potentional solutions:
    1: switch the X and Y axis, telling Mach4 and ESS that x is y and vise versa.
    or
    2: make all Z - become Z + in the Fusion360>Mach4 Post processor (something you might have to do when editing post processors for mulitcham machines?)
    or:
    Physically move the Home switch of the z axis to the lower end.
    (I obviously dont want to do this as you wanna have your z retracting when homing, to prevent damage)
    Oct 2008
    47
    Re: Goal; a working post processor for Fusion 360 to Mach4
    I figured it out.
    Fair and tidy to let you know I guess.
    I flipped the Z axis back.
    What now applies is the settings as shown in the attachements.
    Attachment 485504
    Attachment 485504Attachment 485506
    Attachment 485508
  1. Does anyone have a Laser and Mill post processor for Fusion 360 and mach4 ess
    By raptor_demon in forum Autodesk Post Processors
    Last Post: 12-22-2020, 04:49 PM
  2. Fusion 360 post processor
    By mirocha in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-04-2020, 08:32 AM
  3. A working post processor from Fusion 360 to .mmg?
    By KannaKraft in forum Autodesk CAM
    Last Post: 11-01-2019, 10:54 PM
  4. Fusion 360 Post Processor
    By brianbonedoc in forum Smithy
    Last Post: 03-10-2017, 05:55 AM
  5. Working fusion 360 post processor
    By keithmcelhinney in forum Novakon
    Last Post: 04-13-2016, 05:35 AM
