Originally Posted by
peteeng
Hi All,
I'm looking for a 4 core shielded cable with 1.0mm2 or 0.75mm2 conductors in OZ. There's lots of 1.5mm2 around bit that's too heavy for a 1.5kW spindle. Its a bit stiff. Any clues out there? I'm in northern NSW. I can get 0.5m2 and double it up but that sounds odd....The spindle came with loose 18AWG (0.75mm2) wires. I could just keep them separated from the other cables but would be neater to run them through the same cable track. From memory the manual said 200mm separation. May try to use unshielded and see how that goes, can get 3 core+earth in 1.0mm2 easily in unshielded. Peter
Hi Peter,
I have both 0.75mm and 1.00mm VFD cable.
https://www.homanndesigns.com/index.php?main_page=product_info&cPath=55_11&products_id=249
https://www.homanndesigns.com/index.php?main_page=product_info&cPath=55_11&products_id=228
Cheers
Peter
Homann Designs - http://www.homanndesigns.com/store
