586,042 active members*
3,825 visitors online*
Results 1 to 5 of 5
    Jun 2014
    1780
    Axis backlash setting syntax
    I have tried all the admin commands for setting backlash to no avail!
    I want to set Y backlash to .002 as backlash is approx .0028 now, I would like to know the proper syntax to enter this. In older versions there were commands to enter each individual axis backlash, I dont see these commands on version 2.8.3 which is what I am using now.
    any help appreciated
    thanks
    mike sr
    Jan 2016
    99
    Re: Axis backlash setting syntax
    Any reason you don't want to adjust the thrust bearings to minimize the backlash?
    Dave
    Jun 2014
    1780
    It is just an access problem, I cant get to them without moving a shelf assembly or moving the machine out of position, either is a major hassle.
    I realize that this isnt the way to fix the problem correctly though. I did run a couple parts and the anomaly improved with backlash added and I at least know where the problem is.
    I did figure out the syntax to get the backlash set.
    mike sr
    Feb 2009
    42
    if you know how to modify your .ini file.
    just need to add BACKLASH = 0.002 in the Y Axis section.
    Jun 2014
    1780
    Quote Originally Posted by Nixxk View Post
    Thanks for the reply, I did eventually figure out the syntax for it.
    mike sr
  1. Problem with Backlash setting
    By leomonti in forum PlanetCNC
    Last Post: 07-23-2022, 11:13 AM
  2. Looking fo help setting my backlash on my Microkinietics CNC Express
    By PHSS in forum Uncategorised MetalWorking Machines
    Last Post: 11-04-2010, 04:27 PM
  3. Z Axis Backlash
    By gleas in forum Novakon
    Last Post: 07-17-2010, 11:18 PM
  4. Setting the backlash on End block
    By Ferrari2007 in forum DIY CNC Router Table Machines
    Last Post: 12-16-2009, 09:30 PM
  5. Setting Backlash with Turbocnc
    By ecope in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-11-2009, 08:36 PM
