586,060 active members*
4,167 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > 120v Spindle and VFD recommendation
Results 1 to 6 of 6
    Jul 2008
    31
    Question 120v Spindle and VFD recommendation
    I'm currently in the process of putting together a QueenBee after being away for ~10 year with a DIY wood CNC. At that time I was running a Bosch Colt 1HP trim router.
    This time arround I would like to go the Spindle and VFD way to keep noise down and to get something a bit more powerful. I mostly do woodworking and *some* aluminium.
    I have been reading trough threads trying to find the best combo for 120v (Canada) currently available but havent found a clear answer.
    Huanyang seems to be the best VFD for 120v. Is there a recomended model?
    What about a Spindle 1.5kw (I know I wont reach the max on 120v)?
    Is there a preferred aliexpress store to use?
    15362
    Re: 120v Spindle and VFD recommendation
    Quote Originally Posted by boboxx View Post
    The Bosch Router most likely will outperform the 110v 1.5Kw rated spindle
    G-Penny has the better spindles a Genuine Huanyang is a good VFD for any of these spindles just get the VFD Drive the next size up from your spindle rating 1.5Kw spindle 2.2Kw VFD
    If you can add a 240v single phase line, would be best 1.5Kw and 120v supply is not a great performer, 220v spindle 1.5Kw work really well if you run a 240v line for your machine do a 4 wire 30A circuit then you can have 120v and 240v from the same circuit for your machine, which is the correct way to do it.
    Mactec54
    Jul 2008
    31
    It's pretty easy for me to add 240v and will be doing it for my tables. So if the 120v spindle is that horrible I might as well go 240v
    Would I be better off with a 2.2kw combo or stick to the 1.5kw?
    Attachment 485702
    links:
    https://www.aliexpress.com/item/1005004449456860.html
    https://www.aliexpress.com/item/4001313892297.html
    15362
    Attachment 485702
    links:
    If your machine can handle a 2.2Kw then yes go with that, water cooled is the preferred spindles to buy also
    Mactec54
    Jul 2008
    31
    Ok I'm back to the 1.5kw combo from G-Penny as the 2.2kw with a 30amp circute would cost me to much to put in.
    https://www.aliexpress.com/item/1005002502639247.html
    The VFD is listed as 6.5amp is that correct?
    15362
    The Spindle is listed as 6.5amps the VFD Drive would be more than that may be 7A to 8A for the 1.5Kw VFD
    Some of the specs are incorrect being air-cooled spindle it has a minimum speed of around 8,000 to 12,000 RPM depending on how well the fan works
    This is 220v so are you going to install the 240A 30A circuit, you can install this yourself with some guidance
    So, the 220v spindle amps at say 7A this will require 15A / 240v at the input to the VFD Drive
    Mactec54
  1. Replies: 1
    Last Post: 09-23-2016, 06:25 AM
  2. Replies: 6
    Last Post: 07-10-2015, 10:38 PM
  3. Spindle and VFD recommendation
    By texasinmi in forum Uncategorised WoodWorking Machines
    Last Post: 05-08-2015, 02:37 AM
  4. help with 120v vfd and 220v spindle replacement
    By jimmineycricket in forum Chinese Machines
    Last Post: 04-19-2014, 12:15 AM
  5. spindle and VFD recommendation
    By telah in forum DIY CNC Router Table Machines
    Last Post: 07-04-2011, 02:55 PM
