586,106 active members*
3,157 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Failure setting servo gain
    Oct 2022
    I have a Fadal 15 XT. Today we had an overtravel hardstop in the Y. The machine will jog on all axis but when a command control is sent we immediately get a "Failure setting servo gain" fault. ??? Is this an issue with the controller card? Can I swap controller cards from different fadals.
    Feb 2014
    227
    Re: Failure setting servo gain
    I would start by reading this and check.
    https://flintmachine.com/images/uplo...ve_Systems.pdf
    may have bad gain pot on board or drive or loose wire.
    Be very careful with the trim pots and easy to break off, I did just that. I used to big of screw driver to adjust mine and had to solder it back on the drive.
