586,068 active members*
3,876 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > VFD A2-8022 wire connection with Bsmce04u-pp board
    Oct 2022
    Hello I built a homemade CNC, I can run the spindle from the VFD inverter, now I would like to connect it to the usb board.
    Does anyone know which pin I need to connect?
    Thank you very much
    15362
    Re: VFD A2-8022 wire connection with Bsmce04u-pp board
    Quote Originally Posted by Rex12 View Post
    Thank you very much
    Do you have the VFD PDF Manual that you can post
    Mactec54
    Aug 2023
    Question Re: VFD A2-8022 wire connection with Bsmce04u-pp board
    I have same problem...or two problems...I think.
    This is what I have :
    https://eur.vevor.com/spindle-motor-...p_010384570403
    But is AIR cooled not water cooled.
    and this is user`s guide:
    https://www.et.byu.edu/~sorensen/A2%20VFD%20Manual.pdf
    and my controller card is this :
    https://studylib.net/doc/25734527/bi...verted-wjv-2.2
    First problem is that I cannot get spindle controled by mach3 trough controller card (bitsensor) no matter what I tried. Now the spindle is controled by VFD panel buttons.
    Second problem is that although I managed to run spindle (from VFD panel buttons), after 30-40 minutes of running is geting very hot (cannot keep fingers on spindle for more that 5 seconds (I don`t have a thermometer...)
    Is normal that air cooled spindle to run that hot ?...or how hotter this kind of spindle will be when is running.
    In spindle connection manual the connection plug is wrongly drawn. I use a multimeter to see which is motor coil and I get 3 pins with continuity between them and the forth pin is free without any connection (not ground, I tried to measure if is connexion between this and motor case but is not).
    I think the settings of that VFD is the problem but not shure.
    I use this spindle to carve styrofoam (polystyrene)
    Please help.
  1. Anyone used/using Vevor 2.2kw VFD ? model A2-8022
    By n0f8r in forum DIY CNC Router Table Machines
    Last Post: 09-12-2022, 07:12 PM
  2. VFD A2-8022 - 2.2KW Spindle - BITSENSOR BSMCE04U-PP - MACH3
    By Tesseract-UK in forum Spindles / VFD
    Last Post: 04-04-2022, 01:55 PM
  3. Connection of VFD with pxb usb control board
    By shanu4454 in forum Phase Converters
    Last Post: 08-03-2014, 07:00 AM
  4. Replies: 0
    Last Post: 08-03-2014, 06:59 AM
