586,103 active members*
3,404 visitors online*
    Jun 2022
    12
    Fanuc O-T not ready on startup
    Hey guys just got this topper lathe plugged in for the first time.
    I have this popping up, can’t find anything in the book.
    Any suggestions ?
    Lathe is stuck on this screen on power up.
    0669-06
    Servo: 9046-09
    Pmc : c302 - F5
    Fanuc copyright 1988-1995
    Not ready
    Dec 2009
    953
    Re: Fanuc O-T not ready on startup
    Press the "POSITION" key and than display the alarm
    i think it is related to emergency stop,button or limit switches for the axis travel
    Aug 2007
    793
    Look into wiring diaram on X21.4 signal and you will find out what can cause this alarm.
    Along with emg button and limit switches this can be air pressure switch
    As a rule, there is a button "overtravel release" to interlock limit switches
    Mar 2020
    Hi
    My cnc lathe fanuc OT got problem with monitor when start up machine hydraulic is OK but no display. When the problem started every time I start up the machine the four fuses in the power unit blow out, I replaced the power unit with a second hand one tested OK, fuses no more blow up but the problem still no fixed no display.
    Would you please help.
  1. Daewoo Lynx 200 Startup not ready
    By HarborTwo in forum Daewoo/Doosan
    Last Post: 05-03-2022, 07:37 PM
  2. Fanuc 11M has no startup
    By techbunny2018 in forum Fanuc
    Last Post: 12-07-2018, 02:54 PM
  3. Fanuc 18i- MA "Not Ready" on startup!
    By John Keats in forum Fanuc
    Last Post: 09-16-2014, 10:20 PM
  4. Fanuc 6T startup procedure?
    By laka in forum Fanuc
    Last Post: 05-31-2012, 08:31 PM
  5. "Not Ready" at startup
    By christoph in forum DNC Problems and Solutions
    Last Post: 08-04-2007, 02:55 AM
