586,271 active members*
3,856 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > Servo driven tailstock programming
Results 1 to 7 of 7
    Hey all I am running a space turn lb4000ex with an osp200l control. I am looking for help on how to program the tailstock to move with no manuals for this machine in the shop.
    So what i am looking for is an example on how to move the tailstock from home engage the part to run and then send it home when done.
    Jun 2015
    4154
    Re: Servo driven tailstock programming
    hy
    M56 : tailstock moves near part, then clamps
    M55 : tailstock moves away from part
    those codes work togheter with positions defined into the tailstock table, that can store up tp 10 different sets; also, if you are intersted, is possible to define those positions by g-code
    when you use the tailstock, is needed to define turret index positions, and aproach/depart movements, in such a way, that it won't hit the tailstock
    if you wish to setup fast, i can guide you remotely, answer all your questions; you will be up to it in no time / kindly
    Apr 2006
    822
    Quote Originally Posted by deadlykitten View Post
    hy
    Wrong Kitty,
    M56 Extends the Tailstock Quill - Not the whole tailstock
    M55 Retracts the Tailstock Quill
    In the past, I have used G152 Wxxx to move our tailstock into position, but that tailstock was a drag along, not servo driven.
    Regards
    Brian.
    Jun 2015
    4154
    M56 executes between 0:23 and 0:40
    www.youtube.com/watch?v=7FLCILCse3A
    G55 and G56 do not work with this machine because there is not a quill. The whole tailstock moves as a unit. G152 does not work because it is not a tow along. M482 lools like it might be it but i do not know how to use it. Says it moves tailstock to work support postion.
    Jun 2015
    4154
    no manuals
    pls find attached / kindly
    I have used G152
    hy broby i haven't used it, but from manuals, seems to work as an imaginary w axis, requiring also M188/189, for joint control
    Attached Files Attached Files
    Apr 2006
    822
    Yep that is true, but on the machines I have used with G152, the M codes are built in to the G152 command.
    The W axis is the setable tailstock position.
  1. Tailstock programming
    By Darth Yoda in forum Fanuc
    Last Post: 02-15-2013, 04:19 PM
  2. Parameter for programming tailstock
    By Captdave in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-25-2012, 09:58 AM
  3. Programming Tailstock
    By dcskid in forum Hardinge Lathes
    Last Post: 04-17-2009, 12:10 PM
  4. Event Driven Programming
    By Karl_T in forum CamSoft Products
    Last Post: 04-13-2009, 04:03 PM
  5. EA/ISO programming of tailstock
    By Alutrends in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 04-22-2008, 09:54 AM
