586,121 active members*
3,181 visitors online*
    Oct 2010
    18
    Ref All Home, Slaved axis does not synch.
    Newbie here, well on the learning curve, yet a ways to go. Here's my problem:
    When I 'ref all home' everything works well (Mach 3). The Y axis is driven by two leadshine servo's (Y and Slave A). I can jog around and even run a trial g-code program without issue. BUT, if I jog well off of home (say 40" in Y direction), stop and then select 'ref all home' the A slave axis lags the Y location, alot! Any Idea how this can be happening? By the way I have checked my hardware and there does not appear to be anything slipping mechanically (shaft and belt pulleys matched marked).
    I don't think it is related, but shortly before this happened I ran Axis Calibration in the settings page for the Y leg. It only changed the multiplier by a small amount, since it was only a few thousandths off over 15 inches. I assume even if the A leg had the older value it wouldn't be that far off. Besides when jogging and running a program they seem to be in synch.
    May 2012
    231
    Re: Ref All Home, Slaved axis does not synch.
    Y axis and A axis should be the in motor setting. if y is 4000 step per Inch or mm the A needs to be the same acceleration is set at 50 the have to match be no differences at all. I copy and past setting from y to A so I do not miss type anything then save every change with every copy.
    Dec 2023
    Verify the slaving setup for the Y and A axes in Mach3. Verify that they are configured as a slave axis correctly. Make sure that Mach3 and your gear (such as the actual wire) have the slaving setup appropriately soccer skills world cup
  1. Mach3 ref all home with slave axis
    By HuguesP in forum Mach Software (ArtSoft software)
    Last Post: 12-01-2020, 08:25 PM
  2. Mach3 Limit/Home issue with slaved axis
    By Dub_ in forum Machines running Mach Software
    Last Post: 11-29-2015, 06:16 PM
  3. What is the gcode to ref 1 axis home after
    By seanreit in forum Uncategorised MetalWorking Machines
    Last Post: 12-07-2008, 11:18 PM
  4. slaved motors aren't working in synch
    By axisdd in forum DIY CNC Router Table Machines
    Last Post: 03-15-2006, 08:59 PM
