586,075 active members*
4,011 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > Mori Seiki MT2500 MSX-501 Controller tool change help
    Good Morning,
    I am by no means a new Machinists, but am completely new to Mori controls and also to the mill turn side of things. The company I work for Purchased a Mill/turn for a great deal and everything is working good on the machine. Tech did a tool change without a tool in spindle and said everything looked good (I am almost positive he might of just did using the manual ATC function). I have started playing with and getting myself familiar with the control, but for the life of me can not get this machine to do a tool change.
    I have not done anything with the tool offsets page or registration as there is no data in there and I am just assuming I do not necessarily need any data just to swap to a different tool. I am using G361 cycle like the book says to do and have what i believe is correct based off of the manuals I have read. Below is what I have been trying and keep ending up with the EX0021 alarm tool unclamped as soon as I press cycle start even if I got the machine in single block. I have tried to locate this alarm but it is a PLC alarm and it does not show it in the book that is included on the control with the alarms listed.
    Any help or guidance is much appreciated- Alex
    O1000
    G00 G28 U0 V0
    G28 W0
    G28 A0
    G99
    G54
    M19
    T1001 (machine says tool 1005 is in spindle at the moment)
    G28 A0
    G361 B0 D1
    M00
    Mar 2012
    6
    Re: Mori Seiki MT2500 MSX-501 Controller tool change help
    It's little tricky, Depends how machine was left off, but its doable.
    If machine have 40 tool mag, it easy.
    Go to Settings
    type 10 [Imput]
    Select ATC Manual
    Should be like that
    1 ATC door close - on
    2 ATC door open - off
    3 TOOL HEAD CL - off
    4 TOOL HEAD UNL. - on
    5 MAIN ARM HOME POS - on
    6 TOOL CLAMP - on
    7 ROT. AXIS ORT. - off
    8
    9
    10 POT ATC LOCK - on
    11 off
    12 off
    13 POT ATC POS. - on
    14 POT LOCK - on
    15 POT UNLOCK- off
    16 MAGAZINE INDEX - ON
  1. Tool Life management MSX-501 Controller
    By makwa in forum Fanuc
    Last Post: 12-26-2023, 06:56 PM
  2. Tool Life management MSX-501 Controller
    Last Post: 11-02-2017, 08:02 PM
  3. Mori Seiki ZT1500Y controller MSX-501
    By Kwi4137 in forum Mori Seiki Mills
    Last Post: 06-04-2013, 03:45 PM
  4. Mori Seiki MSX-711IV (PDF manuals)
    By gunrights in forum Mori Seiki Mills
    Last Post: 07-04-2012, 10:44 AM
  5. Replies: 0
    Last Post: 10-02-2007, 07:57 PM
