587,067 active members*
3,667 visitors online*
IndustryArena Forum > CAM Software > Alphacam > No A values in the negative!
Results 1 to 2 of 2
    Whenever i send out a continuous 5 axis program with Alphacam it will never output negative a values no matter how I configure the machine. I have been led to believe it is not an issue with my post because it simulates in ACAM without rotating A to a negative value the C axis Rotates instead and besides my bit turning at 18001 rpm its not helpful at all. also when i send out 4 axis moves on either A or C axis I get full rotation on them. any help would be greatly appreciated thanks!
    Apr 2015
    327
    Re: No A values in the negative!
    check in your post this.
    Template postprocessor:
    $577 Allow Positive and Negative Tilt (1 = Yes, 0 = No).
    Vba postprocessor :
    .AllowPositiveAndNegativeTilt = True
    Do not know your next logic inside, but this primary solve this issue.
    Have a nice day.
    - - - Updated - - -
    Vba postprocessor :
    Have a nice day.
    Alphacam post and VBA macros, Autodesk HSM post.
    www.cadcam-softcz.cz
  1. X negative to X positive
    By Rick_B in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-04-2022, 12:36 AM
  2. A axis not tanking negative values.
    By Fxsm12 in forum Fanuc
    Last Post: 12-03-2018, 04:27 AM
  3. Y values negative instead of positive
    By Wayne Krammer in forum NCPlot G-Code editor / backplotter
    Last Post: 03-13-2011, 04:25 PM
  4. Negative Molds
    By schllac in forum Moldmaking
    Last Post: 12-04-2010, 05:57 AM
  5. Negative Buttress
    By byrdo in forum Uncategorised MetalWorking Machines
    Last Post: 06-07-2010, 01:47 PM
