586,036 active members*
3,636 visitors online*
Results 1 to 1 of 1
    FS Taig cnc mill Model 2019
    I have a Taig Cnc mill , model 2019cnc , will cut plastic , aluminium and steel . Cutter holders and some tools .
    Up graded motor to industrial grade variable speed motor , tooth belt drive , spare belt .
    Comes with computer all set up to run , uses Mach3 , motion drive , transformer , monitor . Weight assist system on Z axis . Enclosure and tray included also ,* I have used flood coolant with this before*
    Price $5500 ono
    Location Gold Coast Qld
  1. CAD Model of Taig Mill Spindle, housing and mounting.
    By JOliver in forum Taig Mills / Lathes
    Last Post: 01-20-2016, 09:14 AM
  2. 2019 CNC mill build log
    By elefant man in forum Taig Mills / Lathes
    Last Post: 04-26-2015, 04:09 PM
  3. taig microproto 2019-ER mach 3 configuration
    By pepperwood in forum Taig Mills / Lathes
    Last Post: 08-12-2012, 03:44 AM
  4. Taig 2019 with Gecko 540 on the way
    By schmutzig in forum Taig Mills / Lathes
    Last Post: 02-14-2012, 03:27 AM
  5. Taig Micro Mill model 2019 Collet & cutter help!
    By conlimon in forum Taig Mills / Lathes
    Last Post: 04-07-2007, 07:12 PM
