586,042 active members*
3,769 visitors online*
Results 1 to 7 of 7
    Apr 2007
    34
    Question Help! anybody have this problem w/ Mach 3?
    I turned the machine on this morning and my page up and down arrows along w/ my r and l arrows wont move the gantry on my machine. Never had this problem before and I cant set the 0 point to run a program. When I fire up a program it moves fine but not when I try to to move it w/ the keyboard.The reset button and shutting down and re starting made no diff.The keyboard is working for other applications but not to move the machine
    Can anyone help if they have had this problem before?I am in a hurry to make a part and a bit jammed up now
    Thanks in advance!
    Jul 2003
    1754
    I will randomly throw something out..
    Num Lock?
    sam
    Dec 2006
    77
    Use the TAB key to get virtual MPG, use your mouse on the screen arrows.
    Apr 2007
    34
    Mach 3 problem
    Thanks for getting back so quickly guys.I thought I would have to wait until this afternoon. Its not the numb lock button but it does move w/ the on screen arrows. Any ideas on whats going on? At least I can move it now, thanks a bunch
    S
    Try resetting your hotkeys. Config>Hotkeys.
    Apr 2007
    34
    Thanks again Ger, I will give that a try.
    sconklin,
    For what it's worth I had the same issue more or less but with my page down button for the Z axis. Using the Jogging flyout window I could move the Z both +- but not with the page down. I completely forgot about being able to reset the HOT KEYS!!!
    LAter,
    Tim
  1. home problem with mach 3
    By Bill Wann in forum Machines running Mach Software
    Last Post: 11-02-2012, 04:06 PM
  2. Anybody had this problem in Mach 3?
    By pointcloud in forum Mach Mill
    Last Post: 07-13-2007, 02:09 PM
  3. Jog problem with Mach 2
    By jtriggs in forum Mach Mill
    Last Post: 06-15-2006, 06:48 AM
  4. Mach 2 Estop problem
    By dentman in forum Mach Software (ArtSoft software)
    Last Post: 06-08-2005, 01:32 AM
  5. mach 2 problem
    By cncadmin in forum Mach Software (ArtSoft software)
    Last Post: 01-16-2005, 09:12 PM
