586,094 active members*
3,830 visitors online*
Results 1 to 7 of 7
    Dec 2012
    71
    Fanuc 0-MD - Message Not support
    I got a second hand Yang 500 machining center just over a year ago. I powered it up and all I could move the table etc so I was happy.
    I had to do a massive rearrange of my workshop as I needed access on all 4 side to the new machine. I basically had to do a complete refurbish of my machines and benches I had accumulated over 20 years. It took me just over a year to complete it.
    When I originally got the Yang I replaced the batteries and Fanuc said they would last a year. The voltage on them today was quite low. My guess is that they will last a year while the machine is on every day.
    Now when I powered it up, I get the message 'Not Support'. Mr google does not give any results for this?
    Any suggestions ?
    I did backup all the parameters last year.
    Aug 2007
    793
    Re: Fanuc 0-MD - Message No support
    Take a photo of this message, please.
    Dec 2012
    71
    Ok, it is what I thought but could not find anything on the web for this. The batteries were that low, it lost it's settings.
    I phoned Fanuc NZ today and they talked me through a few tests. On the motherboard, there 6 LEDS. 2 and 4 were on and RED. I did a 'reset' by holding Reset and Delete and powering on the system and I got my screen back. Now I have a green LED showing on the MB
    Luckly I saved all the software settings when I originally got the machine.
    There seems to be a lack of information/forums on Fanuc. Does anyone know of an active group? The MB LED was a give away but I can't find any info on this, even in the manuals.
    In hindsight, I replaced the CRT with an LED display from Ebay and I think the 'Not Support' was a display message (no signal) and not a Fanuc one.
    Cheers Wallace
    Aug 2007
    793
    Re: Fanuc 0-MD - Message Not support
    You should get "911 ram parity error".
    Now you have to put in rs232 parameters by hand, then options by hand (or through rs232 pushing eob+input) and parameters.
    Hope you backed up 900's parameters (OPTIONS), PMC DATA and 9000's program (if they existed) as well. When you save parameters, Do it pushing eob+output - in this case you save options also.
    There are plenty of info How to do it on this forum and on internet.
    https://www.kfasllc.com/memory_backup_restore_F0.htm
    Dec 2012
    71
    I backed up everthing via RS232 when I got the machine. I had no message at all on the screen.
    Thanks for the link. I have printed it out and booked marked the page.
    Aug 2007
    793
    Quote Originally Posted by marsheng View Post
    At first check power supply on the MB
    Dec 2012
    71
    Just an update. The message was from the new LED screen I installed and not from the Fanuc controller. Basically the batteries went flat and I had to do a software reset to get the machine to wake up.
    Still busy with reloading the software.
