586,121 active members*
3,661 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > PlanetCNC > Laser cutting New Year’s decoration with PlanetCNC TNG
    Mar 2017
    1312
    Short tutorial on how to use Image Import feature has been published. It describes how to easily generate suitable gcode for laser cutters using only TNG software.
    https://planet-cnc.com/laser-cutting...planetcnc-tng/
    If you have any questions, tips or suggestions, let us know
    Best regards, Team PlanetCNC
    Feb 2019
    76
    Re: Laser cutting New Year’s decoration with PlanetCNC TNG
    doesn't work well
    1) the laser turns on too early, before reaching the starting point. because of this, it burns everything in its path
    2) nothing is visible on the preview
    3) you need to press the preview button 2 times.
    better do this for DXF
    Mar 2017
    1312
    It works very well. You are doing something wrong.
    1. You did not set spindle settings correctly
    2, 3. Preview toggles between showing processed image and outlined image
    You can send me your image and I will make screenshots of whole process
  1. PlanetCNC TNG software crashing
    By S3eed77z in forum PlanetCNC
    Last Post: 10-07-2020, 07:09 PM
  2. Spindle synchronisation with PlanetCNC TNG
    By PlanetCNC in forum PlanetCNC
    Last Post: 09-08-2019, 08:49 AM
  3. PlanetCNC TNG Slave Set Up
    By Gdog in forum PlanetCNC
    Last Post: 12-28-2018, 01:44 PM
  4. Issues with PlanetCNC TNG
    By nucutza in forum PlanetCNC
    Last Post: 11-19-2017, 10:23 AM
  5. PlanetCNC DIY Controllers and TNG
    By ccandiotes in forum PlanetCNC
    Last Post: 08-01-2017, 10:28 AM
