586,379 active members*
2,891 visitors online*
Page 3 of 3 123
Results 41 to 42 of 42
  1. #41
    Jun 2022
    24
    Re: Oiling the ER collet nut?
    With respect of the motor axis?
  2. #42
    Jun 2015
    4154
    if you refer to something like a damaged chuck cone, for example, let's say that the tool got stuck, and the collet rotated like crazy inside the cone ... then the cone should be refreshed
    take away the part, corect it, put it back
    ... or
    corect directly on the machine
    hmm ... do you wish to know if your chuck cone is tilted ? or you are sure that is tilted, and wanna know how to corect it ? i think the 1st one is that you are after
    All was going fine (0.004-0.005 mm of runout) until... I picked the ER20 collet for 4mm dia tools.
    Bang!
    Runout between 0.07 and 0.11 mm!
    this shows a problem with a collet; i would check the o4mm collet
    if chuck cone was &^&**&(, then you would have not noticed those 4-5um runouts, but bigger values
Page 3 of 3 123
  1. G0704 Z ball nut oiling
    By hscess in forum Benchtop Machines
    Last Post: 12-13-2016, 06:02 PM
  2. Collet nut imbalance
    By Azalin in forum Spindles / VFD
    Last Post: 08-01-2014, 03:14 PM
  3. Collet wrench for a ??? collet nut
    By burnettm in forum Want To Buy...Need help!
    Last Post: 12-28-2012, 09:14 PM
  4. ball screw/nut oiling
    By timbeaulieu in forum Bridgeport / Hardinge Mills
    Last Post: 07-23-2012, 08:56 PM
  5. Sherline Collet Nut
    By mikkojay in forum Benchtop Machines
    Last Post: 01-19-2008, 05:58 PM
