586,082 active members*
3,566 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > Inventor iLogic CAD model to generate toolpath for specific CAD profiles , Not all
    Apr 2022
    Hello,
    Complete newbie, I'm using iLogic to configure a door stile (#hinges, inswing/outswing, length of door etc.) in the CAD environment. I have generated toolpaths for all the different configurations the CAD outputs. But when I regenerate the toolpath based on the iLogic, the entire .nc code for all the tool paths is posted instead of the ones selected by iLogic and are visible. Is there a workaround around this, to only post the G-code for configured profiles? Or Inventor CAM does not have this capability?
    Any help, much Appreciated.
    Jan 2018
    1516
    Re: Inventor iLogic CAD model to generate toolpath for specific CAD profiles , Not al
    In the past what I've done is to copy the same complete cad file multiple times on the pc.
    So example if I have a cad file with 5 operations I would:
    Copy (duplicate) the file 5 times on the pc, so xxxx1-5
    Leave #1 tootlpath on cad #1 and delete the rest.
    On file #2 leave toolpath #2 and delete the rest.
    On file #3 leave toolpath #3 and delete the rest.. Etc...
    Then you can now post each toolpath individual.
    If you are already using iLogic, you could just suppress the operation using iLogic.
    AddReference "C:\Program Files\Autodesk\Inventor CAM 2023\R27\Autodesk.InventorHSM.Interop.dll"
    imports Autodesk.InventorHSM.Interop
    Sub Main()
    Dim addin As ApplicationAddIn
    addin = ThisApplication.ApplicationAddIns.ItemById("{749E6 67C-2560-416A-A5E7-68B96FF997B1}")
    Dim api As Object
    api = addin.Automation
    Dim addinApi As InventorHSMAddinAPI
    addinApi = addin.Automation
    Dim hsmVersion As String
    hsmVersion = addinApi.Version
    Dim hsmEdition As HSMProductEditionEnum
    hsmEdition = addinApi.ProductEdition
    Dim hsmDocs As HSMDocuments
    hsmDocs = addinApi.HSMDocuments
    Dim docVersion As String
    Dim hsmDoc As HSMDocument
    hsmDoc = hsmDocs.Item(ThisApplication.ActiveDocument)
    docVersion = hsmDoc.Version
    Dim ops As HSMOperations
    ops = hsmDoc.AllOperations
    Dim op As HSMOperation
    For Each op In ops
    If op.Name.Contains("Test") Then
    op.Suppressed = True
    End If
    Next
    End Sub
  1. very useful site for specific cad files
    By reefy86 in forum Mechanical Calculations/Engineering Design
    Last Post: 04-13-2015, 03:31 AM
  2. need inventor cad part model for new design
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 11-23-2009, 07:38 PM
  3. Anyone have Autodesk Inventor X3 Cad files?
    By caleb105 in forum Benchtop Machines
    Last Post: 02-16-2009, 08:11 PM
  4. scan part and generate cad code?
    By ATV in forum Uncategorised CAM Discussion
    Last Post: 02-14-2008, 07:56 PM
