586,042 active members*
3,748 visitors online*
Results 1 to 1 of 1
    Aug 2018
    29
    Align linear rail with straight edge.
    Following situation I need to align my linear x rail. The rail is 4000mm long an 20mm wide. So I couldn't afford to mill an edge to lean it on. So I decided to make an epoxy bed 40mm wide and 5mm high to level it in z. Now I'm thinking of how to get it straight. I have a straight edge wich is class 0 so it's pretty straight. But it's only 500mm long. I found in the forum a clever method by using an electric wire.
    https://www.cnczone.com/forums/mechanical-calculations-engineering-design/19418-layout-centerlines.html
    But it's from 2006. So I wonder if there are some more recent ideas to solve it. Maybe you could direct me there
  1. Align two straight linear rails in one plane
    By flexbex in forum Linear and Rotary Motion
    Last Post: 01-03-2023, 10:42 AM
  2. Replies: 0
    Last Post: 09-05-2019, 06:20 PM
  3. Align to edge of sheet function
    By alan_3301 in forum LinuxCNC (formerly EMC2)
    Last Post: 01-23-2013, 12:03 PM
  4. Using the edge of Routing Table as Linear Rail
    By senojnayr in forum Linear and Rotary Motion
    Last Post: 03-27-2011, 08:35 PM
