586,075 active members*
4,283 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > SCHAUBLIN 100 CNC vertical center error tool magazin
    Question SCHAUBLIN 100 CNC vertical center error tool magazin
    Hello, I have a SCHAUBLIN 100 CNC vertical machining center. The problem is that the magazine with the tool is blocked.
    Control is FANUC 0i-MC. There is no error on the display, only the ATC light is on. The machine does not go to the reference points, the ATC alarm is constantly activated, it cannot be reset with the RESET button. I checked the limit switches on the tool magazine, they are correct, the magazine is in a good position. There are two inductive sensors for the tool position on the magazine spindle, both are activated. Does anyone have an idea where the error is.
    Re: SCHAUBLIN 100 CNC vertical center error tool magazin
    Solved, Due to a bad power supply, the 24v dc machine was losing the order of the tools.
    Fixed power supply and reinserted tool parameters.
    It works now
    hello,
    Now I have another problem on the same machine.
    When drilling a hole, the number of revolutions of the spindle decreases, there is no power.
    If I go with the drill 10 mm after the drill enters the material two to three millimeters, the spindle stops completely.
    The machine does not throw an error.
    I checked, there is no slipping on the belts.
    please help
    Dec 2015
    171
    Could please help me regarding same machine backup files [email protected]
    Greeting,
    I didn't see the message, if you didn't decide to send it to you.
  1. mazak VTC20B T plus error 212 magazin
    By wojtekthx in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-04-2020, 09:17 PM
  2. Replies: 3
    Last Post: 02-19-2020, 07:57 AM
  3. SCHAUBLIN 43 CNC automatic tool changer Problem
    By heeerekarjp in forum Fanuc
    Last Post: 06-14-2015, 08:03 AM
  4. stock Vertical Turning Center, CNC Vertical Lathes, SMTCL VTC6070
    By SMTCL Europe in forum News Announcements
    Last Post: 05-09-2011, 12:57 PM
  5. CNC Vertical machining center
    By soumen in forum Mori Seiki lathes
    Last Post: 03-11-2008, 03:06 PM
