586,113 active members*
3,582 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > Fadal 4020 reviving rigid tapping capabilities but running into spindle overload.
Page 2 of 2 12
Results 21 to 23 of 23
  1. #21
    Aug 2009
    1573
    Re: Fadal 4020 reviving rigid tapping capabilities but running into spindle overload.
    ...so, the Yaskawa worked with Param A1-02 set at 3 (Closed Loop) without the Encoder. That doesn't make sense. The drive should have faulted out #10
  2. #22
    Aug 2009
    1573
    ...well, I see a 1010-4 Card on ebay with ELE-0025 Chipset that are in horrible condition. (I've seen better n worse $500 chips...lol ) But, at the price the seller Offer to me ($100) because I put it on my watch List for the photos might be worth it..If the seller has guaranteed to work.
    https://www.ebay.com/itm/18549750824...Bk9SR_bqgb2VYQ
    Nexgen (406) 600-0624 is one of original Fadal Engineers that build Fadal's and the last time I called them (few years back) they answer all my question how to get a 4th axis setup...No Charge. We talked for 45 mins. So, I would call them after the Holiday and chat with them if, all else fails.
    Keep us posted,
    DJ
  3. #23
    Feb 2014
    227
    Quote Originally Posted by Jeremy_Sawatzky View Post
    Here are the images for what I see on the SETP pages. - the spindle options dont show anything for rigid tap although there are other settings that mention it. - Gain and Ramp.
    I have a 1400-4 card that is compatible with my 1010-4 spindle control card as per the chart.
    The 1400-4 card has a V94.10-3 2494 chipset version on the 1610-1 memory card.
    The 1010-4 card has V92.1X eeproms installed on it.
    Did you get the rigid tapping figured out? If so what was the issue?
Page 2 of 2 12
  1. Replies: 6
    Last Post: 10-21-2020, 04:57 AM
  2. Help with Rigid Tapping on Sub-Spindle
    By cjhayes in forum Fanuc
    Last Post: 03-12-2020, 07:33 PM
  3. Fadal 4020 motor overload
    By Oviksnc in forum Fadal
    Last Post: 07-09-2016, 05:47 AM
  4. High production rigid tapping on Fadal?
    By imaginemw in forum Fadal
    Last Post: 08-27-2011, 05:50 AM
  5. Fadal 4020 Rigid Tapping Limits?
    Last Post: 02-24-2011, 06:36 PM
