586,036 active members*
3,523 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > MC V machine, OSP U10M control. Heavy Tool
Results 1 to 6 of 6
    Mar 2020
    4
    Having trouble putting new tool in the tool data page. Need to add a heavy tool. Must be missing something. Procedure attached. I cannot highlight the tool I want to edit
    Nov 2007
    352
    Re: MC V machine, OSP U10M control. Heavy Tool
    Put D as in dummy tool beside the L designated for this
    Heavy tool is different again as it changes in one motion but slows tool changer --------Large emptyies the spindle and then brings the large tool in
    Jun 2015
    4154
    hy Ishingleton that is basically what any tool change does
    large requires the nearest pots to be empty, so between tool out from spindle, and new tool in, there is atc motion / kindly
    Nov 2007
    352
    Heavy Tool and Large tool are two different things in the control
    Dec 2008
    3109
    I seem to remember that for large tools, the toolpots on either side need to be "dummy" pots.
    If the adjacent pots were cleared, then, setting middle pot as large would set adjacent pots as dummies.
    The same may required for "Heavy"
    ... note... this setting may not be available on your machine. Ones I operated, it did nothing
    ( if in a production type environ.)
    I also remember there was a procedure that cleared the entire magazine, or was it setting pot1=tool1 etc... I can't recall
    Someone else would have to chip in with that info.
    Mar 2020
    4
    Thank you all who replied. I was on the wrong page! There are two pages that are almost identical. They both list the pot and tool number. Only one of those pages will allow the tool to be changed.
  1. OSP-U10M
    By jonisantos in forum Okuma
    Last Post: 07-31-2019, 04:07 PM
  2. Okuma OSP U10M Spindle control problem
    By ungie in forum Okuma
    Last Post: 04-21-2019, 08:51 AM
  3. Replies: 7
    Last Post: 01-11-2014, 11:09 AM
  4. Okuma osp-u10m
    By babanh in forum DNC Problems and Solutions
    Last Post: 01-18-2012, 02:29 PM
  5. Replies: 3
    Last Post: 06-21-2011, 02:30 AM
