586,626 active members*
2,434 visitors online*
IndustryArena Forum > CNC Electronics > Spindles / VFD > Spindle sound issues - video
    Jun 2008
    36
    During warm up, the spindle does not sound right at the highest RPM (24000). I thought the sounds was a much higher squeal pitch, whereas now it is much deeper and louder – as in it made me rush to see if everything was ok. Perhaps it is just me, but I wanted to get your thoughts. I recorded video of it and uploaded to my YouTube channel – the issue occurs right after the 3:53 point.
    https://youtu.be/Nrpd2WKXidk?t=230
    15362
    Re: Spindle sound issues - video
    Quote Originally Posted by szavoda View Post
    Sounds like the Bearings are on the way out in the High-speed range, how old is the spindle and how much work has it done
    Mactec54
    Jun 2008
    36
    Only 2 months old with just a few hours on it. I will have to see what Camaster support wants to do. I had some stuff I wanted to do over the weekend - not sure if I should....
    15362
    It sounded ok in the mid-range speed so run it in that range, is this an air-cooled spindle, it could be the fan that has a problem if it is air cooled, and the noise could be from there, it's too new for it to be Bearing but you never know, check the fan though
    Mactec54
    Jun 2008
    36
    Turns out it was a particular 3/8" bit that was causing it. New bit with only a few cuts on it, but who knows. I ordered another to see if it changes things.
  1. Strange sound from the spindle and freezing of the machine!
    By Thomas91 in forum Chinese Machines
    Last Post: 12-17-2020, 03:13 AM
  2. Omio CNC X8 Spindle Sound
    By bl775 in forum Chinese Machines
    Last Post: 09-10-2017, 09:20 PM
  3. spindle sound sabre 750
    By hotrunner in forum Cincinnati CNC
    Last Post: 04-29-2016, 09:55 PM
  4. Spindle Motor Fan sound is annoying!!
    By CNC Viking in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-30-2009, 11:02 PM
