586,110 active members*
3,162 visitors online*
Results 1 to 9 of 9
    Jun 2016
    57
    G81/G83 can cycles on 0T
    Is it possible to use G81/G83 can cycles on 0T? We cannot seem to figure this out. Machine is a Hardinge Conquest lathe. Parameter change?
    Nov 2007
    352
    Re: G81/G83 can cycles on 0T
    On a lathe on Z axis drilling try G74
    Dec 2005
    504
    I run an 0TA control on a SZIM lathe. As lshingleton mentioned, you'll want to use G74.
    You may find this handy:
    https://www.helmancnc.com/simple-cnc...rilling-cycle/
    Aug 2007
    793
    Parameter 909#3 usually opens this option
    Dec 2009
    953
    Quote Originally Posted by guhl View Post
    Please do not show option paramater in public
    you have to do it in private
    Please read the rules
    Will not be a next time
    cheers
    Feb 2006
    992
    How old is the machine? older machine probably not have it at all.
    The best way to learn is trial error.
    Apr 2018
    134
    Quote Originally Posted by zavateandu View Post
    cheers
    I'm posting this message as a CNCZone Moderator.
    I, and several other Moderators, are not aware of a rule that says "option parameters" can not be posted in CNCZone threads. We would welcome a link to such a rule, or further explanation.
    Dec 2008
    3109
    Quote Originally Posted by RaderSidetrack View Post
    Oh-oh
    You cannot fathom the can-of-worms you have just opened
    Hope your pockets have lots of cash to pay the suits from FANUC for allowing propriety info to be displayed on a public forum
    You may as well say its OK to allow ppl to put up pirate software links for CAD or CAM wannabes
    Dec 2008
    3109
    Found the rule....
    Posted by CNCAdmin as a "Sticky" @ the top of Fanuc forum
    https://www.cnczone.com/forums/fanuc/53037-cnc-software-4.html
    I suggest the "Moderators" take a refresher at their rules & regs.
  1. Replies: 0
    Last Post: 02-11-2021, 08:00 PM
  2. Help with G81
    By Steven74 in forum G-Code Programing
    Last Post: 11-28-2012, 03:02 PM
  3. Mach3Turn Canned Cycles G81-G89
    By sysel in forum Mach Lathe
    Last Post: 05-27-2012, 12:15 AM
  4. need help with drill cycles, G81 etc.
    By cabledude in forum Machines running Mach Software
    Last Post: 12-08-2011, 11:00 PM
  5. Why is G81 doing this?
    By Rico55 in forum Machines running Mach Software
    Last Post: 05-20-2011, 08:33 PM
