586,052 active members*
3,992 visitors online*
IndustryArena Forum > WoodWorking Machines > CNC Machining Centers > Sharp 2412 tool changing problem
    Nov 2006
    13
    Actuator/cylinder is not releasing the retension knob fingers do to lack of travel. Any suggestions?
    Dec 2006
    242
    I had that problem with my Mighty machine a couple of years ago. After a whole lot of trouble, I got it working again without being really sure what it was. I was not down on hydraulic fluid, but that would be my first recommendation: there is probably an air over hydraulic cylinder in the back of the machine. The force needed to release a tool is higher than can bemade with 90 psi shop air without the use of an enormous cylinder, so they make hydraulic pressure and use a smaller cylinder. You likely are down on fluid and there may be air in the system even if you replenish the fluid. Feel free to email me at [email protected] with any questions. A call to the dealer might help. Personally, I'll spend days trying to fix a machine myself before calling them in at $95/hr with a 4 hr minimum. I've saved thousands over 8 years just learning to fix tool jams, spindle orientation, backlash adjustment, electrical shorts,etc.
  1. Sharp SV-2412
    By Larry B. in forum CNC Machining Centers
    Last Post: 10-12-2007, 02:58 PM
  2. Postprocessor for Faunc Oi Mate-MB on Sharp 2412
    By Mickey_D in forum SprutCAM
    Last Post: 07-21-2007, 11:51 AM
  3. 6M quit tool changing
    By Drew in forum Fanuc
    Last Post: 01-23-2007, 07:32 PM
  4. Tool changing G30.1
    By ben92 in forum G-Code Programing
    Last Post: 11-17-2005, 08:57 AM
  5. ' 04 VF 4 Rough Tool changing
    By active-precision in forum Haas Mills
    Last Post: 09-26-2005, 01:56 PM
