586,102 active members*
2,606 visitors online*
    Nov 2022
    Unhappy Prt-e1500w does not reset
    Hello everyone,
    following a reset with D176 command, when I restart the CNC it appears as per the attached picture, do you know a way to reset the board?
    The only thing that does not work is the spindle, otherwise the cnc works fine.
    Thank you very much
    Jun 2005
    1730
    Re: Prt-e1500w does not reset
    The photo shows you have the machine in manual mode. What happens when you press the RUN button? You did not explain exactly what is happening.
    Nov 2022
    Hello, do not turn the spindle, neither in manual mode, nor in pc, nor using pc and controlled by pc, everything worked before. After the D176 command it is as if it went into protection
  1. 6040 cnc PRT-E1500W vfd settings.
    By koolkleptokidd in forum Chinese Machines
    Last Post: 05-04-2021, 04:23 PM
  2. Replace Internal PRT-E1500W With External - Can It Be Done?
    By TaffyCarl in forum Chinese Machines
    Last Post: 04-20-2019, 11:19 PM
  3. PRT-E1500W Controller issues
    By DarbyOhara in forum Chinese Machines
    Last Post: 02-16-2019, 03:09 AM
  4. 6040 cnc PRT-E1500W vfd problem
    By koolkleptokidd in forum Spindles / VFD
    Last Post: 03-18-2018, 11:52 PM
  5. CNC controller PRT-E1500W problems
    By Tanasky in forum Chinese Machines
    Last Post: 06-09-2017, 11:37 PM
