586,103 active members*
3,703 visitors online*
IndustryArena Forum > MetalWorking Machines > CNC Swiss Screw Machines > CITIZEN Machines > M20 Live tool on turret will not go above 500rpm
Results 1 to 9 of 9
    Apr 2011
    25
    M20 Live tool on gang will not go above 500rpm
    I have a Cincom M20 that works great except for the live tooling on the turret. This spindle will not go above 500 rpms.
    The problem is with the turret, not the gang. I couldn't edit the title.
    Not sure where to start, any suggestions would be appreciated.
    Jan 2013
    126
    re: M20 Live tool on turret will not go above 500rpm
    Do you have a G50 s500 somewhere limiting the speed??
    Apr 2011
    25
    No, I don't think that is the issue. Recently I tried to run a program and use the turret to drill a cross hole in a part. I thought if I fed slow enough 500 rpm would work. Whenever the part reached the point in the program where the turret live tool would start, I always get an "P32 Address Error". At this point, I just have to stop everything.
    Machine works great with the exception of turret live tools.
    Jan 2013
    126
    That would mean there is something wrong with that line of code. Can you post that operation??
    Jan 2013
    474
    Quote Originally Posted by jreynolds5 View Post
    Can you check the analog input voltage to the live tool spindle drive at various speeds ?
    Ie what is current voltage?
    Voltage at 50%
    Voltage at 100%
    Usually 0 to 10vdc (from O to max rpm).
    Apr 2011
    25
    Re: M20 Live tool on turret will not go above 500rpm
    When it errors out, all 3 lines are in the G720 machining mode. $1 is commanded "G720", $3 is commanded "G720W1" and $2 is commanded as below. I get the error immediately after the turret live tooling spins up at the line that says "S4=1000M83 (TURRET_LIVE_ON)". Let me know if anything stands out as being obviously wrong. Thanks.
    $2
    G710W1
    G720U1
    P17(BIG_HOLE)
    N2501
    T2500(0.201_LIVE_DRILL_TURRET_HOLDER)
    G50 W0.790 U0.75(OFFSETS)
    G98(IPM_FEED)
    M70 (CAXISON)
    G0C0
    G4U0.5
    Jan 2013
    474
    Quote Originally Posted by kunz82414 View Post
    $2
    G710W1
    G720U1
    P17(BIG_HOLE)
    N2501
    G98(IPM_FEED)
    M70 (CAXISON)
    G0C0
    G4U0.5
    Have you got a speed limit set in the tool data ?
    If your program speed is higher than the preset it could give a fault.
    Jan 2013
    126
    I would add the line of code in blue. G50 is modal so if you had a spindle speed limit set in another program of anywhere else it will pick it up.
    $2
    G710W1
    G720U1
    P17(BIG_HOLE)
    N2501
    G50 S5000 (SETS MAX RP,)
    G98(IPM_FEED)
    M70 (CAXISON)
    G0C0
    G4U0.5[/QUOTE]
    Apr 2011
    25
    I tried adding the "G50 S5000 (SETS MAX RPM)" line of code, but still having the same issue with the error message "P32 address error".
    I will try to test some voltage readings going to that spindle and see what I find out.
    Appreciate the help.
  1. Turret and Tool Live Graphics Preview Question
    By sanddrag in forum Tormach Slant Lathe
    Last Post: 06-11-2017, 07:19 PM
  2. Ciitizen M20(m1 series) live tool bearings
    By OMS2010 in forum CNC Swiss Screw Machines
    Last Post: 08-17-2016, 06:47 PM
  3. CITIZEN M20 TURRET TOOL CALLING
    By SHEKAR in forum CNC Swiss Screw Machines
    Last Post: 12-13-2013, 11:19 PM
  4. Citizen M20(Classic M20) turret A-axis programmin
    Last Post: 08-13-2012, 09:06 PM
