586,114 active members*
3,248 visitors online*
Results 1 to 12 of 12
    Jun 2014
    1780
    After market oiler
    I bought one of these oilers from ebay to oil the Z ways and ballscrew, it works but the oil leaks out due to the orings not being sized correctly, so I made a mandrel for a larger oring, to use in the lathe, then cut the oring down with a sharp cutter by trial and error until it had a medium resistance when installed, so far it works fine.
    Maybe a bit off the wall but it works..
    mike sr
    Oct 2008
    2100
    Re: After market oiler
    I am (was) running an ebay oiler on my Tormach KMB1 mill. I tested the original oiler (which still works) to determine exactly how much oil it dispensed each time it was activated. Then I programmed the new oiler to dispense the same amount of oil on the same time interval. Works/ed just fine.
    The electro mechanical clockwork trigger for the air operated oiler failed, so I just slapped on the programmable ebay oiler because I already had it on hand. They seem to work just fine. The Tormach automatic oiler seems to just be another variant of the same thing. I have them on all three of my Speedmasters as well.
    Bob La Londe
    http://www.YumaBassMan.com
    Apr 2011
    720
    Are you guys talking about one of these, or something else?
    Terry
    Oct 2008
    2100
    That is one variant.
    Bob La Londe
    Jun 2014
    1780
    I was talking about the manual version, they were cheap for a reason.......
    mike sr
    Oct 2008
    2100
    Quote Originally Posted by popspipes View Post
    Oh, Okay. All my CNC machines have automatic oilers. I do have a manual oiler on my knee mill and my surface grinder, but they came that way.
    Bob La Londe
    Apr 2011
    720
    I'd like to get a manual one to replace the broken one on my surface grinder.
    Do you have a link, or brand name Mike?
    Jun 2014
    1780
    Quote Originally Posted by MFchief View Post
    https://www.ebay.com/itm/12396169746...3ABFBMlNWw3Zph
    This is one thats similar Terry, I did this a couple years ago and I dont have a link to that particular one.
    It does work well to keep the Z oiled, I still check it often though, and this saves quite a bit on oil as well, I wasted a lot pumping the original one several times to get oil to the Z.
    mike sr
    Jun 2014
    1780
    This one is in the states and cheaper.
    https://www.ebay.com/itm/35349478638...f35ph&LH_BIN=1
    mike sr
    Apr 2011
    720
    Thanks, that's exactly what I need, just ordered the second one you linked, thanks very much.
    Terry
    Jun 2014
    1780
    I mounted mine on the left side of the column, and run it thru a small 4MM check valve to prevent backflow if there is any.
    mike sr
    Apr 2011
    720
    Sounds like a good addition, for not much money. These days I use my 1100 seldom enough that I always manually apply some oil to the z before using it. Might need to order a second one.
  1. Laser cutting in the market needs to develop in the market
    By jackmiao in forum Plasma, EDM / Other similar machine Project Log
    Last Post: 07-13-2018, 02:04 PM
  2. X5 Speedmaster Oiler
    By Bob La Londe in forum Syil Products
    Last Post: 04-12-2018, 03:09 AM
  3. X4 Speedmaster Oiler
    Last Post: 04-04-2018, 01:30 AM
  4. Oiler help
    By SFIYA in forum For Sale Only
    Last Post: 11-18-2013, 06:01 PM
  5. Automatic Oiler vs Manual Oiler
    By bruce34rr in forum Tormach Personal CNC Mill
    Last Post: 05-19-2010, 04:21 AM
