586,051 active members*
3,644 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport mill table screw movement
    Dec 2022
    We have an oldish (1950s?) vertical mill. When manually moving the table left to right or right to left, the L.H. handle is permanently engaged. The R.H. handle is disengaged until you push, pull or rotate the part of the handle that you hold. It will then engage & move the table. Is it possible to change/adjust this R.H. handle so that it is permanently engaged? Having to hold the handle into engagement is awkward if you are also trying to look closely at the workpiece to make small adjustments.
    Aug 2008
    406
    Re: Bridgeport mill table screw movement
    That is a safety handle for the power . It can be replaced for a standard handle.
    15362
    Quote Originally Posted by Nigh View Post
    You can take the spring out and add a spacer on the other side, to engage it full time.
    Mactec54
  1. Screw question & funky movement
    By Serb in forum Joes CNC Model 2006
    Last Post: 10-01-2009, 05:39 PM
  2. fixed screw vertical movement
    By mccafferty in forum Linear and Rotary Motion
    Last Post: 01-25-2009, 09:11 PM
  3. Manual Ball Screw Movement
    By dafowfidy in forum Haas Mills
    Last Post: 12-10-2008, 04:33 PM
  4. WTB: Lead screw nuts for Bridgeport Style MSC (Taiwan) knee mill for X and Y
    By modernprecision in forum Want To Buy...Need help!
    Last Post: 03-03-2008, 08:02 PM
  5. has anyone seen an aluminum table for an old J-head bridgeport mill?
    By xhardwaremanx in forum Bridgeport / Hardinge Mills
    Last Post: 11-19-2005, 09:06 PM
