586,121 active members*
3,440 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > 15331 Touch sensor retract LS is not On
    Dec 2022
    10
    hi, i have a problem with a Okuma p100, the error is 15331.
    con you help me to solve the problem.
    how i fix the error
    Apr 2009
    1262
    Re: 15331 Touch sensor retract LS is not On
    There is normally a proximity switch that detects when the arm is fully up. It may may require a little adjustment. There should be an indicator light on the prox showing when it is retracted.
    Experience is what you get just after you needed it.
    Dec 2022
    10
    thanks for your support okumawiz
