586,119 active members*
3,564 visitors online*
    Nov 2022
    18
    G270 lathe code?
    Wondering what this code is, fusion 360 outputs, but my machine doesn’t recognize it, I can delete and the program runs. Haven’t found that code in a list yet.
    Nov 2007
    352
    Re: G270 lathe code?
    What machine are you using with what control ?
    Jun 2015
    4154
    Hy chris g270 is not critical, even if the lathe recognises it, it can run without it
    Is equivalent to m109
    270 71 72 are used to designate a machine mode : turning, interpolated milling, or non interpolated milling ( y axis ) / kindly
    Nov 2022
    18
    It’s on a L370mw - osp e100L - it runs fine without it. I wish I could find out what to change on the post to have it not in there
    Jun 2015
    4154
    Hy chris, in case you dont figure out that post, i can fix your code automatically
    It will scan and remove g270, or do whatever you wish / kindly
  1. T-32 lathe G-code example anybody?
    By underdog in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-28-2017, 12:37 AM
  2. Lathe code idea for Z
    By skipper_52 in forum DIY CNC Router Table Machines
    Last Post: 05-23-2008, 12:28 AM
  3. AutoCad to lathe g code
    By allanwinks in forum Autodesk
    Last Post: 12-16-2007, 08:40 PM
  4. fanuc 11 lathe g-code
    By bobcor in forum Fanuc
    Last Post: 08-20-2006, 08:16 PM
