Re: What could cause a end mill to drop DOWN in collet?
hy this happens mostly to endmills with helix flutes; during heavy cutting, apears a tendency ( somehow similar to a nut that is rotating on a screw ), that may shift your tool and/or your part
during heavy side milling, most endmils have a tendency to be pulled out of the collet, because most helixes are Z type; for the tool to be pushed in, requires a reversed helix, thus S type, but this are not common items; just like metalmayhem sugested, secure the endmill with a side screw if endmil's shank is stright, use a grinder to make kind of a flat, so to be sure that the tool won't be pulled out
even more, on powerfull machines, during heavy facing with large tools with tilted insert seats, the stock may be raised from the vice, so it is recomanded for such high mrr operations, to use reversed tilted seats ( thus kind of chaninging the toolholder, from one that uses positive inserts, to another for negative ); i just remembered, another condition is that ae ( that one from ae & ap ), when ae<tool dia, must be centered with the tool axis, so to avoid high servo loop reaction for the axis that is not feeding / kindly
