587,013 active members*
3,644 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > shop teacher needs fast feedback
    Sep 2007
    Exclamation shop teacher needs fast feedback
    Folks
    a little background -
    I am a retired Mechanical Engineer Tech. I have been teaching shop for six years at the high school level in Iowa. This year, I am teaching a power course. I want to help the kids build a scale model of an old time factory. We will use a scale model steam engine (from Graham Industries - driven by compressed air) to turn two overhead line shafts. The line shafts will drive two rows of machinery below them. The kids will design, build and millwright the machines. The machines will be small (they would fit in a 5” x 5” x 5” cube). Each machine will perform a simple operation on a work piece as it passes down the conveyor line (which they will also build).
    The kids will machine from scratch all the parts that go to build their factory machines.
    I am avoiding CNC for this course. My kids are struggling with math concepts. As you know, kids are fascinated with the process of machining. It has big draw power. But their math abilities are weak. Making chips will be the carrot. Crunching the math for setup and manually driving the tables will be the stick. This is going to be fun.
    what i need!!!!
    I am late in getting started on this. The kids are raring to go and I am still ordering stuff. I am going to use Taig manual mills and one Lathemaster model ZAY7045FG mill. I am trying to determine the limits of the Taigs - i will shift tose jobs to the lathemaster. One limit may be the durability of the Taig table. Is it aluminum or iron?
    Second - we will be boring and reaming in brass to 5/8" dia x .75 deep. Assuming I can get around the Z constrictions on the Taig, can it handle the job - or will I just see belt slippage?
    Has anyone bought a Lathemaster model ZAY7045FG mill recently? Mr Bertrand at Lathemaster sounds like a good guy - but not in a hurry. I'm in a hurry - the fault is mine. Any suggestions on how to expedite?
    thanks
    Shopsteam
    Sep 2006
    340
    eBay..
    The machines will probabally work just fine, you will need to use slower feedrates.. And step SLOWLY into the large bores...
    I do not have a mini machine, but small machine = small cuts = steady but complete
    Hey check out my website...www.cravenoriginal.com
    Thanks Marc
    Oct 2004
    168
    Quote Originally Posted by shopsteam View Post
    Folks
    The Taig mill table is anodized aluminum. Table durability isn't really an issue, generally.
    The Taig really isn't good at boring, the slowest speed on the manual mill is 525 rpm, which is just too fast and results in vibration. You really won't enjoy drilling holes much over 3/8" on the Taig, unless you drill pilot holes, and 5/8" drilling is mush too large. As for reaming, again 525 is fast in some material, although not too bad in others. The main problem is the length of reamers. Definitely get the ER16 spindle if you can as it allows a greater range of tooling to be used (although you can only get aftermarket boring head adapters for the standard 3/4"-16 spindle AFAIK)
    Nick
    Nick Carter
    Largest resource on the web about Taig lathes and mills
    www.cartertools.com
    Jul 2007
    1602
    If the kids are going to be making chips I would suggest putting a fixture plate on top of the mill table. These aren't too expensive and can be viewed as sacrificial. Mistakes will happen...
    These are quite reasonably priced:
    http://www.whitewolfairsmithing.com/taig.htm
    Jul 2005
    969
    Quote Originally Posted by rowbare View Post
    i second that its alot easyer to replace a tooling plate then to replace the table and i am about sure a couple of the student will drill further then they are suppose to
    The opinions expressed in this post are my own. -Les opinions exprimé dans ce messages sont les mienne
  1. Taig 3 Jaw Chuck on Taig Mill?
    By jim_stoll in forum Taig Mills / Lathes
    Last Post: 09-19-2017, 04:38 PM
  2. XY table design basics, linear ways to table size ratio?
    By Konstantin in forum Mechanical Calculations/Engineering Design
    Last Post: 03-13-2007, 06:21 PM
  3. Way covers for Taig
    By warpedmephisto in forum Taig Mills / Lathes
    Last Post: 06-19-2006, 07:59 PM
  4. Taig CNC help
    By Grimracer in forum Taig Mills / Lathes
    Last Post: 03-14-2004, 04:32 AM
  5. EDM for a Taig?
    By teilhardo in forum Waterjet General Topics
    Last Post: 03-05-2004, 12:36 AM
