586,110 active members*
3,232 visitors online*
    Dec 2016
    51
    12" Z Axis experience?
    I'm considering swapping out the 8" for 12" Z Axis on a Pro with 8" gantry clearance for sculpting HDPE elements positioned on a vertical table fixture. I was hoping for feedback from anyone who owns a machine with a 12" Z Axis to reflect on relative performance. Thanks in advance for your time.
    Jan 2012
    222
    Quote Originally Posted by Mavigogun View Post
    All machines this light will flex and ring. I have dual 12 inch travel axis (Z and U) on an extended gantry 5x10 machine. The 12" length is actually closer to 14 inches travel. You can put longer end mills on the spindle and fully retract them from the work envelop which is why you would need it.
    If you aren't cutting foam with long 5" or 8" end mills there really isn't a point in getting a larger size than the 8" incher that is standard.
    If you are just cutting HPDE then the 8" would be you best bet.
    One thing to consider though, if you get a dual head, extended gantry, get both heads the same length. Otherwise you run into problems with Mach4.
  1. Replies: 3
    Last Post: 12-26-2018, 01:20 AM
  2. Replies: 10
    Last Post: 05-06-2018, 06:59 PM
  3. CNC Gantry from eBay "matzcnc"...comments/experience?
    By DMoneyAllstar in forum Waterjet General Topics
    Last Post: 07-28-2012, 09:10 PM
  4. any experience with plasma "PIERCE RUR 2500"??
    By tibet in forum CNC Machining Centers
    Last Post: 03-29-2008, 09:48 AM
  5. has anyone got experience with "speed demon" linear guides?
    By MatD in forum Linear and Rotary Motion
    Last Post: 01-18-2008, 06:47 PM
