586,408 active members*
2,840 visitors online*
    Sep 2009
    27
    Dyna torch line
    Did anyone pick up the Dyna torch line, as far as I can tell there out of business., My smart motors appear to be all good, that is to say they all have green lights and will work for short periods of time before echo response faults occur. restart and it will operate as normal for a minute or so then fault out again.
    Sep 2009
    27
    Re: Dyna torch line
    O.K we solved the problem on the Dyna Torch, Russell at (cncshopandservice.com) took over the remains of Dyna torch and now has a new line of cnc cutting tables.
    He sent us a complete test procedure for the driver motors on our Dyna torch cutting table. After about an hour of testing the problem was identified.
    They also can supply retrofits kits for the old Dyna's
  1. SDS/2 and Arianna for Ficep Drill/Torch Line
    By sippelsteelfab1 in forum Uncategorised MetalWorking Machines
    Last Post: 11-10-2014, 04:41 PM
  2. Oil in a T100M torch line help
    By WSS in forum Hypertherm Plasma
    Last Post: 11-09-2011, 03:35 AM
  3. Building a Dyna Torch like machine?
    By turboedgs in forum DynaTorch
    Last Post: 08-07-2010, 01:12 AM
  4. opinions on Dyna Torch Plasma table
    By Matt T in forum DynaTorch
    Last Post: 12-11-2006, 06:35 PM
  5. Dyna Torch
    By edwardpic in forum DynaTorch
    Last Post: 10-05-2006, 05:57 PM
